LSiC?
edited January 2010 in Speakers
I need a center for my HT...
Is the LSiC worth the money or can I get something that costs less?
My amp is 150wpc @ 4ohms for the center channel.
Post edited by acmf74 on
Welcome!
    edited January 2010
    The LSiC is definitely worth the money. You can get something better that costs more. I doubt if you will get something equal and new that costs less, but it might be possible to find a high end CC on the used market.
    edited January 2010
    acmf74 wrote: »
    Does the rest of your home theater have speakers from the Polk LSi series? - if yes, the LSiC is what you want. If not - get the center that matches.
    Michael
    edited January 2010
    Try to keep the center and front mains the same series of speakers. Only use the LsiC if your front mains are Lsi9, 25 or 15's. That would be your best bet sonically.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
    edited January 2010
    I agree with Michael and blue. Only get the LSiC if you have the LSi series for your mains. If not then get the timbre matched center for your mains. If you don't know which one it is, let us know what you have for mains and we will let you know. Good luck.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
    edited January 2010
    My two mains are Lsi 15's
    Thanks for the input.....
    edited January 2010
    acmf74 wrote: »
    Match made in heaven, you will be fine.
    -Jeff
    HT Rig
    Blu-Ray- 80 GB PS3
Welcome!
Welcome!
