cylinder subwoofers from SVS
jerjon7
jerjon7 Posts: 41
how do they sound, i can probably only afford the the regular version though having the plus would be nice, either way are they worth it, do they sound that much different then there box counterparts?
Post edited by jerjon7 on
  • ken brydson
    ken brydson Posts: 9,020
    edited January 2010
    jerjon7 wrote: »
    They sound great! Nice small footprint too which makes them easy to place and they are fairly light so they're much easier to move around than their boxed cousins. I have a 25-31PCPlus. The new NSD driver in the entry level subs is really good, in fact I've heard performance approaches that of the earlier Plus drivers if that makes you feel any better. I upgraded my diver to the 12.3 Plus when they offered an upgrade special. Good luck!
  • PSOVLSK
    PSOVLSK Posts: 5,400
    edited January 2010
    jerjon7 wrote: »
    I was never under the impression that they were "better" than the box subs, only that they had a smaller footprint. Could be wrong though.
    pitdogg2 Posts: 27,301
    edited January 2010
    well you can make you own out of a concrete(sono) tube. It's what they use to pour concrete pilings and such. I did and I tuned it to 17hz with 15"woofers and a 1000 watt amp to run it. Made a cloth covering for it or you can glue carpet to like you can get from parts express
  • kuntasensei
    kuntasensei Posts: 3,263
    edited January 2010
    I have a SVS 20-39CS+ that has been going strong for 4+ years, though I did swap out the original driver for the dB12.3 upgrade. SVS makes a solid subwoofer that will troll nice and deep. I've heard the corresponding box sub here locally, and it didn't sound radically different.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • gelinas
    gelinas Posts: 226
    edited January 2010
    yeah, the boxes and cylinders are generally considered roughtly equlivent (within the same line)
    It really comes to a decision of which one you like the look of better.
    Remeber, the cylinders can be layed on their sides behind a sofa if that works for your situation.
  • jerjon7
    jerjon7 Posts: 41
    edited January 2010
    good stuff, now i just have to decide if i want to get regular version or save up for the plus..hmmmm..
  • eclimax13
    eclimax13 Posts: 168
    edited January 2010
    as a pc12plus owner i can tell you that it is quite impressive....i have mine directly behind my theater seats and its a very enjoyable experience...watching top gun on bluray makes you feel like you are right next to the jets and the bellrock from lotr feels like hes stomping through my house...pretty amazing stuff...once you get a sub that goes this low you'll wonder how you did without it...honestly, save up and get the plus...you might save a little now but probably will regret it later
    Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
    Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
    Bed Room: Panasonic TCP50x1, Samsung Bd c7500
    Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
  • mrbofus
    mrbofus Posts: 297
    edited January 2010
    These look sweet, but Im afaid the cat would think its a new scratching post!!
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
    Onkyo DX-C390 CD Changer
    POLK RTI8 Mains--Cherry
    the rest...in process...slowly!!
  • eclimax13
    edited January 2010
    mrbofus wrote: »
    this is why my theater room door is always closed....the dog must stay out
  • kuntasensei
    edited January 2010
    I've had no issues with my cat. I did, however, put on a loud scene and pause it until she got near it. It only took that one scare to keep her from messing with it. (Plus, it was kinda' funny to watch. Just sayin'!)
    Equipment list:
    Emotiva XPA-3 amp
  • ken brydson
    edited January 2010
    eclimax13 wrote: »
    +1000- Great sub. No replacement for displacement. Love mine. It's not going anywhere until I can swing a PB13 Ultra!
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2010
    jerjon7 wrote: »
    I would go for the Plus.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • spnplgr
    spnplgr Posts: 33
    edited January 2010
    jerjon7 wrote: »
    I just got the PC12-NSD and I love it. It's 3 ft tall but only 16 1/2" wide footprint. I have big room with openings and all hardwood floor. It sounds great. Totally non-directional. Only half the floor space of the box ones. It's located in a corner in front. Very nice sounding bass.
    :)spnplgr
    Frt: Polk RTi8's
    Ctr: Polk CSi5
    Surr: Polk FXi3's
    Sub: SVS PC12-NSD
    TV: Sony KDL-XBR4 46"
    A/V: NAD T-747
    Sony BDP-S300
    Eq rack: VTI AGR404
  • jerjon7
    jerjon7 Posts: 41
    edited January 2010
    good to hear, i think im taking the dive monday and purchasing the regular version
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited January 2010
    Thought I'd ask if anyone has had experience with a passive sub running a separate power amp to it?
    edited January 2010
    Polkie2009 wrote: »
    well it's the way i run mine. I made a 7' tall 24"diameter sono tube with 2-15" woofers and tuned @17hz I run mine with a amp that is of Bob Carver design "tracking down converter" just dont have the Sunfire name 1000 watts into 4 ohm's ....lets just say it can pressurize a room.
  • Polkie2009
    edited January 2010
    Sounds like you have a hard hitting sub there pitdogg2! I've noticed a number of sub companies make passive units you can run with whatever amp you want to use. I've noticed a number of people are using high powered pro audio amps with plenty of watts to feed these.
  • kuntasensei
    edited January 2010
    Polkie2009 wrote: »
    I'm running a SVS 20-39CS+ passive sub with a Samson 1000 rackmount amp powering that and a Buttkicker LFE (500w to each). I'm also passing the SVS' signal through an ART-351 EQ just to use the subsonic filter (since I don't need the EQ itself now that Audyssey has tamed most of my room-induced issues and since the Buttkicker provides the really deep tactile bass).
    Equipment list:
    Emotiva XPA-3 amp
