best setup recomendations
cmendizabal
Good afternoon all of you:
I need some recomendations to setup my following equipments:
2 RTI-A7(LR)
1 CSI-A6(C)
1 DSW PRO 500 (SUB)
4 MIRAGE OMNISAT V2 (SURR)
ONKYO TX-SR806
EMOTIVA XPA-5
MONSTER POWERCENTER
SONY BDP-S350
SONY KDL52XBR6
SKY SATELLITE BOX
ALL MONSTER CABLES
The RTI-A7 must be defined as Fullband?
Any crossover recomendation?
Any DB values recomendation for all speakers?
Crossover for the subwoofer?
I dont have experience on it.
Any help will be really appreciate it??
2 RTI-A7(LR)
1 CSI-A6(C)
1 DSW PRO 500 (SUB)
ONKYO TX-SR806
EMOTIVA XPA-5
MONSTER POWERCENTER
SONY BDP-S350
SONY KDL52XBR6
SKY SATELLITE BOX
ALL MONSTER CABLES
Post edited by cmendizabal on
welcome to the club. I'll try to point you in the right direction with some general info.Theres lots of different ways to do this, so I'll go for the easiest. if the cable box has an hdmi out I'd run that strait to the xbr. run another hdmi from the tv out to receiver. run an hdmi from the bdp to the receiver. on most receivers you have to asign the hdmi to the corresponding components in the receivers settings. you have the choice of running a set of your surrounds off the amp and a set from the receiver, but the onkyo will power them just fine and free up a little juice in the amp - your call. run 3 interconnect cables from the receivers pre-outs(if you decide to run all your surrounds from the receiver) into the amps designated inputs. left front out from receiver to left front in to the amp. do this with right front and center also. run the speaker cables from amp outputs to the corresponding speakers. run a set of speaker cables from each of the receivers outputs - surround left/right and surround back left/right to each of the corresponding surround speakers. run a sub cable from the designated sub out on the back of the receiver.make sure all your speaker connections are secure. plug all your components in to the monster power strip but NOT the amp, plug that into its own outlet. try to keep all power cables away from anything carrying a signal, speaker wires ect..take your time with cable management. The instructions for the onkyo will explain how to run the audessy setup and its the best place to start. you can fine tune and tweek from there.cmendizabal wrote: »Good afternoon all of you:
2 RTI-A7(LR)
1 CSI-A6(C)
1 DSW PRO 500 (SUB)
ONKYO TX-SR806
EMOTIVA XPA-5
MONSTER POWERCENTER
SONY BDP-S350
SONY KDL52XBR6
SKY SATELLITE BOX
ALL MONSTER CABLES
hope that helpspanasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
①
◊ Main speakers - SMALL - crossover to 60 Hz,
◊ Center - SMALL - crossover to 60 Hz,
◊ Surround - SMALL - crossover to 60 Hz,
◊ Subwoofer - crossover to 60 Hz,
◊ LFE (Low Frequency Effects) channel - crossover to 120Hz.
②
◊ Main speakers - SMALL - crossover to 80 Hz,
◊ Center - SMALL - crossover to 80 Hz,
◊ Surround - SMALL - crossover to 80 Hz,
◊ Subwoofer - crossover to 80 Hz,
◊ LFE (Low Frequency Effects) channel - crossover to 80Hz.
③
◊ Center - SMALL - crossover to 100 Hz,
④ ⇓-Preference-⇓
◊ Main speakers - LARGE,
LSi are speakers at 4 ohms. Check processor.
01) DENON AVR-4308CI: Advanced 7.1 CH/5.1+2 CH/ 3.1+2+2 CH A/V Home Theater /MultiMedia Multi-Source/Zone Receiver with Networking and WiFi/170 watts x 7 channels
02) SUNFIRE Grand Signature - Bob Carver's
03) OPPO DV-980H 1080p Up-Converting Universal DVD Player with HDMI and 7.1CH Audio
04) OPPO BDP-83 Blu-ray Disc Player w/SACD & DVD-Audio / DENON DVD-2500BTCI: Blu-ray Disc DVD/CD Digital Player/Transport
05) HITACHI P55T501. 55" HD1080 Plasma HDTV
06) POLKAUDIO LSiC (Center speaker)
07) POLKAUDIO LSi15 LEFT (Front speaker)
08) POLKAUDIO LSi15 RIGHT (Front speaker)
09) POLKAUDIO LSif/x LEFT (Surround speaker)
10) POLKAUDIO LSif/x RIGHT (Surround speaker)
11) VELODYNE OPTIMUN 12" (High Output Digital EQ SubWoofer 2400W/1200WRMS) -
thank you Bernal for your advice.
which one of the options do you recomend for my RTI-A7
and CSI 6 Speakers?? -
cmendizabal wrote: »thank you Bernal for your advice.
2 or 3
