MBL 101 E Radialstrahler Omnidirectional Loudspeaker
Bernal
Bernal Posts: 991
edited January 2010 in Speakers
MBL 101 E Radialstrahler Omnidirectional Loudspeaker...any feedback on this speaker......thanks
Post edited by Bernal on
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    It's ugly as hell. :)
    tonyb Posts: 33,072
    edited January 2010
    Didn't those power the starship Enterprise ?
  • ESavinon
    ESavinon Posts: 3,067
    edited January 2010
    One of the best sounding speakers i've heard at any price.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • halo71
    halo71 Posts: 4,632
    edited January 2010
    I bet them dang flux capacitor's are expensive to replace though! :p
    --Gary--
    nooshinjohn Posts: 25,925
    edited January 2010
    I would love to get my ears on a set of these.
  • superjunior
    superjunior Posts: 1,632
    edited January 2010
    looks like a space heater
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • Ricardo
    Ricardo Posts: 10,636
    edited January 2010
    I heard them powered by all MBL gear. The best speakers I've heard. If I hit the lottery this is what I will get.
    SOPA
    F1nut Posts: 51,772
    edited January 2010
    I've listened to them more than a few times, but I just don't like their presentation. The lack of a defined center image bugs me.
    tonyb Posts: 33,072
    edited January 2010
    Never heard them, but have read many a review. Your the first I can remember anyway, that pointed out the lack of a center image. Interesting, since these speakers are in no uncertain terms, cheap.
  • Ricardo
    edited January 2010
    Interesting; I thought imaging in general, including center was very good. I will have to invite you over when I get them.
    SOPA
    treitz3 Posts: 19,992
    edited January 2010
    The model pictured above is what I believe I auditioned at Jolida HQ's hooked up to about $120K worth of MBL gear. What I heard was nothing special whatsoever and with certain aspects, completely unbearable. Here's a quick observation of what I heard...
    Steady, constant, unbearable hiss or extremely high frequency. Especially when up close to the tweeters in all directions [within 7 feet]. This occurred whether or not there was a source was playing or not. It bugged me so much that I would literally put my hand between the speaker and the tweeter when I walked by them because it physically hurt my ears and it was constantly audible whether music was playing or not. It wasn't quite the mosquito tone as it was a tad lower but VERY noticeable and completely annoying. If you can't hear these types of frequencies, then this would not be an issue.
    The mid bass was sloppy and slow with a low attack. Bass was virtually non-existent and what you did hear was very sloppy. Horrible integration between the two lower register drivers. Mid-range was sweet, but nothing spectacular.
    The top end was very present, omni-directional and at times pleasurable. That said, it seemed to mimic electrostat's and ribbons by throwing sound all over the place. They did fill the room, but [to me] at an expense of spatial location cues. Here's an example; when listening to a particular instrument, the speakers threw the sound out in its spatial image and while doing so, smeared the instrument back and forth at the same time. This would make a guitarist that would normally be just inside the right speaker [for example] be just inside the speaker but it would place/stretch him in front of the speaker as well as behind the speaker at the same time. It was just an unnatural presentation for me.
    It had a slight SDA effect on certain instruments, but I believe that it only happened on instruments that hit a certain frequency. I say that because I only heard the effect [if you will] during the same frequency which was around the frequency of the upper notes of a chime. Overall, frequency-wise], the top end was complete but it still missed the last little bit of the uppermost "pings". Very nice and realistic roll off.
    Overall as a speaker? I wouldn't want them, nor would I recommend them. I think that they bite the big one and I've heard a better bottom end on a pair of white van speakers. In fact, the setup in the room next door sounded much more realistic, pleasing and musical. That rig consisted of a pair of Noel bookshelves powered by the new Jolida FX-10, which is a 10 watt integrated tube amp. That, I would recommend.
    edited January 2010
    treitz3 wrote: »
    It bugged me so much that I would literally put my hand between my ear and the tweeter when I walked by them
    Allow me to correct this sentence.
