Hookup questions for dual subs
Mobius
I have:
Polk RM-705 HT system (including it's sub)
Polk PSW-111
Onkyo TX-SR304
Obviously, I'm not looking at winning any awards with my setup, but it suits me and my small living room well. I know this setup is for HT, but it pulls double duty as occasional radio/CD music.
Currently I have a Y adapter on the back of my amp with a decent RCA cable connected to the subs. One side is going to the R port on the RM-705 sub, and the other is going to the L port on the PSW-111.
My questions:
1. Is this the best way to connect the subs? The PSW-111 has an LFE jack whereas the RM-705 sub does not. Should I put Y adapters and run each line into both the L and R jacks on each sub? Should I use the LFE port on the PSW-111, even though the RM-705 doesn't have one?
2. Where should I be looking to set my crossovers on the amps and/or the receiver? Polk recommends 120Hz, I think, but that seems to get too much high frequency bass into my music. Sounds okay in the movie soundtracks.
3. The room is carpeted, thus the down-firing RM-705 is pushing the bass straight into it. Is this going to muffle/alter the bass appreciably? Would it help to put the sub on a piece of MDF or something similar? What about turning it on it's side?
Polk PSW-111
Onkyo TX-SR304
My questions:
Post edited by Mobius on
Welcome to club Polk!
If you're running satellites, which you are...you really should follow what Polk recommends or you will have a hole in your bass...missed frequencies.
Small sats can't handle anything below 120hz.
Thanks for the info. That's kind of what I was thinking. Just wanted some reinforcement.
Does anyone have any thoughts on my other questions? With the PSW-111, should I even bother using the sub that came with my RM-705 system? It sounds much boomier than the PSW-111, but I'm wondering if that's because it on carpet, or just a lower quality unit? Thoughts?
