to keep amp or not keep amp??
cstmar01
cstmar01 Posts: 4,424
edited January 2010 in Electronics
sooo I decided I have to upgrade my AVR. I was trying to decide if I wanted to get an AVR or save a bit and get a pre/pro. I decided to go with an AVR as I'm sick of the one I currently have and can't decide for the life of me what pre/pro to go with and wanted to give myself some time to see if I can get my ears on one and play with them a bit to see what I like and then decide.
SO the AVR I will be getting will mostly likely be the Pioneer Elite SC-05 or 25. Now I had a 2 channel amp for my rears which I sold, 3 channel for the center and surrounds, and the mono blocks for the front. I won't get rid of the mono blocks as I have RTIA9's and want to give them a bit of power. I sold the 2 channel as I can run those rear surrounds easily off the new AVR. However I don't know if I should get rid of the 3 channel. Its an Emo XPA-3. I would be upgrading it anyways once I decide on a pre/pro with probably parasound or something similar but just don't' know if I should shed it now or later.
A lot of people said that I would probably not notice a difference between the pio's amp section for the surrounds and the XPA-3s. My main concern is the center but that's just me.
What do you guys think? I'm just kinda stuck because if I can sell it thats fine and dandy and if I don't sell no big deal but just need a little push one way or the other.
Thanks!
Post edited by cstmar01 on
    heiney9 Posts: 25,449
    edited January 2010
    There is A LOT life outside Emotiva as far as amps go. Sell it and try something different or try something different and then sell which ever one you like least.
  • rcrook317
    rcrook317 Posts: 280
    edited January 2010
    emotiva is the BEST WAY TO GO !
    j/k just like seeing people on here bitching bout emo, its 2 funny! demo around find what u like.....ur ears are the judge,i dont hav enough knowledge to pick one or the other for ya
    fronts=rti12s(cherry)
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    audioquest diamondback 1m
    "Maesto" straightwire cables
    pangea ac-9
    playstation3/120gb=blu-ray/media server
    monitor=lg 55inch lcd(1080p)
    TT Set-up=Pro-Ject RM 1.3
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
    "It doesnt mean that much to me,to mean that much to you"
  • cstmar01
    edited January 2010
    heiney9 wrote: »
    oh trust me, emo was my first amps and I just wanted to try to see what I thought of them. I feel like they lacked some detail to be honest. Ya they got power but I also want something that has a lot of detail. I was thinking about trying Parasound or Rotel once I get my pre/pro and go from there. I really like McIntosh but want to try some others before I would go there.
  • Knucklehead
    Knucklehead Posts: 3,602
    edited January 2010
    My vote is for Adcom. Nice choice on AVR.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • anhchungdoan
    anhchungdoan Posts: 760
    edited January 2010
    Go for the Carver/Sunfire if extra power is needed. They are light weight and running cool.
  • anhchungdoan
    edited January 2010
    rcrook317 wrote: »
    Why? Is it because it is in-expensive :rolleyes:?
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    We can get together sometime, I'll bring my Pioneer SC-07 up by you if you want to compare it to your emotiva amp. In my current HT I'm running all my RTI's off the receiver and the receiver is doing a great job.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2010
    Never mind what other people say, keep it & check it out with your own ears between all the speakers. Once YOU determine the difference, THEN decide what you want to do.
  • concealer404
    concealer404 Posts: 7,440
    edited January 2010
    Dump the amp, get a Pioneer SC, and just enjoy the movies. :)
  • cstmar01
    edited January 2010
    Well after some thought, I decided to sell it and put it up as of last night, and well already have someone that is probably going to be sending me the money tonight. I decided because I do want to move away from Emo amps because like I said they are alright but I really want to expand my horizon a bit and test out other stuff. I will for now just use the mono's for the front L/R and then the SC for the other 5 channels. If I find it doesn't do what I want to do I think I'll just pick up a nice 3 channel parasound or adcom and try that out and see if it gives me the sound I want. Thanks for the advice guys!
