Monitor 5 or 5B?
domflane
domflane Posts: 653
edited January 2010 in Vintage Speakers
I just bought my first pair of vintage Polks over the weekend and I thought they were just Monitor 5's. Then unfortunately, my POS Marantz pre-amp srtuck again and I blew one of the mid drivers. I pulled it out and the back of the MW6502 was stamped with the manufacture date and "5B". So are they 5B's? And whats the difference?
Also, this gives me a good excuse to try my first upgrade. I'd like to try to upgrade the cab, XO's and tweeters, so I'm going to be hitting you guys up for info and advise coming up here soon. I recently bought a nice used set of original MW6502's from a fellow Polkie. Should I use these in my upgrade or is there a better alternative if I'm rebuilding everything anyway? Thanks in advance guys,
Dominic
RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Post edited by domflane on
    heiney9 Posts: 25,432
    edited January 2010
    Monitor 5's were the very early ones with the peerless tweeter, non-bevel front cabinets, velcro tabs for the grills, paper rings on the driver basket, dual protection fuses. Anything later is considered a 5B and can even have the peerless occasionally. I also believe 5's used a MW6500 driver. 5B's come with or without a tweeter fuse.
    I have a pair of early 5B's with the tweeter fuse which I have bypassed.
  • domflane
    domflane Posts: 653
    edited January 2010
    They must be 5B's then, thanks heiney.
  • skrol
    skrol Posts: 3,450
    edited January 2010
    Here are pics of the Model 5 (Monitor 5), Model 5A (Monitor 5A), Monitor 5B and the Monitor 5 Series 2. Hope it helps.
    My Monitor 5A's have the MW 6500 mid-woofers and the Peerless tweeters.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • Conradicles
    Conradicles Posts: 6,343
    edited January 2010
    What kind of tweeter does the Monitor 5 series 2 have?
  • mmadden28
    mmadden28 Posts: 4,283
    edited January 2010
    skrol wrote: »
    Stan
    I have 5A's and 5B's and they are exactly like the pics (the middle 2). Also they are as described by H9.
    I'll dbl check but:
    My 5A's don't have the front bevel but do have the Peerless and the fuses.
    My 5B's do have the Front bevel, but alas no Peerless, but do have the fuses.
    I am pretty sure both (of mine) have the 6502's.
    Both have the Grill pegs.
    One other thing I noted, and you can see it in the pics as well, the 5A has the driver surface mounted, where the driver on the 5B is flush.
    Another thing I noticed is that on one set, the dust cap on the drivers is less like a course woven fabric material, but more like a fiber mesh of sorts. I'm going down now to dbl check.
    According to the parts list the SL2500.
    ____________________
    Pool: Atrium 60's/45's
  • domflane
    domflane Posts: 653
    edited January 2010
    Thanks skrol, from the pics you posted, mine appear to be M5 series 2. I'm still kinda unsure about the differences in the tweeters. I guess mine are SL2500's.
    edited January 2010
    domflane wrote: »
    If the domes are black(ish) and there is a foam ring around the dome then you have Series II w/sl2500.
    This is a smoother tweeter than the sl2000. The Series II were the last of the original Monitor series and made for arguably the nicest sounding because of the sl2500 vs the sl2000.
