Parasound HCA1500A
mopar paul
I'm reluctantly selling my wonderful Parasound amp in hopes of upgrading, though I think I'll have to spend a lot to do so. Anyway, it's in perfect condition with the original box, manual and cord. I have been using it to power my SDA SRS's and it's a great match.
You can buy in confidence that this is as perfect as I say it is, if not, I'll refund your money (unless you blow it up:D). Anyway, the below specs are from Parasound. Price is $475.00 plus shipping. Thanks
Paul
Product Information
HCA-1500A was designed by renowned circuit designer John Curl to meet or surpass the stringent standards required by Lucasfilm for use in THX Home Cinema systems. Each precision component within your HCA-1500A is carefully selected for optimum sound quality on even the most challenging music and film soundtracks.Parasound amplifiers have greater operational flexibility and power than most other amplifiers you may have used. Ideal for both home theater and critical listening, the HCA-1500A is a two-channel amp that's conservatively rated to deliver 205 watts per channel. JFET input transistors and MOSFET drivers offer warm tube-like sound.
Product MPN
MPN HCA-1500A
Key Features
Number Of Channels 2
Remote Control Without Remote Control
Bridgeable Bridgeable
Performance
Audio SNR 110 dB
Frequency Response 5 Hz - 100 kHz
RMS Power at 4 Ohms 315 W
RMS Power at 8 Ohms 205 W
THD (Total Harmonic Distortion) 0.03 %
No. of Speaker Outputs 2 Speakers
Dimensions
Depth 16 in.
Height 5.25 in.
Width 19 in.
Weight 40 lb.
Paul
Product Information
Product MPN
MPN HCA-1500A
Key Features
Performance
Audio SNR 110 dB
Dimensions
Depth 16 in.
Height 5.25 in.
Width 19 in.
Weight 40 lb.
Post edited by mopar paul on
Very nice amp. I used to have one. Good luck.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
Great Amp.....Good luck with the sale!Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
Great amp I had one as well now it's doing justice to my brothers LSI 7s. GL with the sale.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2
My HCA-1500A is 7 years old, I love it. Very good price Paul!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Amp is sold, thanks folks. I hope I dont regret this, these are as good as everyone says they are!
