Monitor 40 on newegg and AM40 speaker brackets question
Hi all, To complete my setup (1 CS2, 2 M70s, Pioneer VSX-9040TXH), I ordered Monitor 40 ($115 a pair on sale this week) today.
I have a question on the RM40 brackets:
http://www.bracketsandstands.com/AM40_SIDE_CLAMPING_WALL_MOUNT_SPEAKER_BRACKETS_p/am40.htm
which seem to be fitting M40s, both dimension-wise and weight wise:
AM40:
5.5 to 11 wide, up to 13 deep and a maximum of 50 lbs
M40:
http://www.polkaudio.com/homeaudio/specs/recent/monitor40/
15-3/4" H x 7" W x 12" D
16 lbs
They do not require any holes to be drilled in the speakers, which is good, since the M40 does not have the provision.
What I am worried about is the possibility that the speaker might "fall down" - in the attached picture to the AM40 link above, the brackets are on the side, and the speaker is going to be facing down toward the listening position, with a tilt. I am worried it might slide off and fall on someones head. Am I being paraonid? Does any one have any experience with AM40 or similar mounts?
Thanks,
Mathru
AM40:
M40:
16 lbs
Thanks,
Mathru
Post edited by mathruj on
that' sa great price for the 40's I paid 150 for mine and was happy at that priceMain 2ch -
BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
TT - Pro-ject Classic SB with Sumiko Bluepoint.
TV 3.1 system -
Denon 3500 -> Dynaudio Excite 32/22 -
I bought the same brackets and speakers last week, I did a lot of reading and the AM40's will work just fine for you. I did put my AM40's on ebay since the wife told me to get stands for the 40's and not mount them after all.Home Theater:
Processor: Emotiva UMC-1
Amps: Emotiva XPA-3, Emotiva UPA-5
Center: Polk Audio CSi A6
Fronts: Polk Audio RTi A7
Surrounds: Polk Audio FXI A4
Surround Rears: Polk Audio RTI A3
Subwoofer: SVS 2039 PCi (upgraded woofer)
Power Conditioner: Monster HTS 5100 Signature Series
2 Channel: (work in progress)
Speakers: Polk Audio Monitor 40 -
I forgot to mention I did also read someone using a zip tie to help them up also, not sure if they attached it to the speaker wire though.Home Theater:
Thanks ScudDawg. It looks like the AM40 comes with 5 screws.
"If desired, screws may be used with the five security screw holes on each bracket to attach the brackets to the speaker sides or bottom."
The AM40 manual is here: http://pinpointmounts.com/resources/AM40_manual.pdf
Is it ok if I drill holes in in M40 on the bottom and back: how far deep can I go without doing any functional damage? -
+1 to that, I got um for the same priceMonitor 60s, CS10 front
Monitor 40s, back
PSW10:(
H/k AVR 325
Sansui Tape Deck
Pioneer PD-5010 CD player
Sennheiser HD 650s
Maverick Audio Tube Magic D1 DAC
AMD Phenom II 940 @ 3.8 prime stabel
4 gigs 1066, cas 5
XFX 4890 1gig
Seagate 1tb 7200.12
Creative X-fI Titanium Fatal1ty -
Guys..please share pics of your new setup:). I will also share as soon as I get all my components and get it working!!
