Connecting turntable to computer
NeilGabriel
NeilGabriel Posts: 1,487
I want to transfer some old 33's my folks have to CDs...I know quality will be pretty bad, but I want to be a good son.
Can I connect the turntable straight to the input on the computer with appropriate connections, or
do I need to run the turntable into an amp and then to the computer?
Suggestions on good recording software to record entire LPs?
Mike
  • jimbo1421
    jimbo1421 Posts: 772
    edited January 2010
    Mike
    Hi Mike. You will definitely need at least a pre-amp to boost the TT output to line level. I use Amadeus Pro ($40, Mac only) http://www.hairersoft.com/AmadeusPro/AmadeusPro.html
    Audacity is free and cross platform. http://audacity.sourceforge.net/
    Regards,
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • Fongolio
    Fongolio Posts: 3,516
    edited January 2010
    +1 to Audacity for software
    If you have one of the newer USB turntables then you are ready to go. There are a few tt's with rca outs that have built in pre-amp but those are pretty rare. I use a Carver CT-Seven for the pre out. I also use an rca to din adapter to jack it into my soundcard. So far the results have been excellent. I gave my dad a vinyl to cd rip of the Eagles Long Road Out of Eden for Christmas that sounds better than the store cd. Have fun!
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • NeilGabriel
    edited January 2010
    Thanks....I'll google some things....I have the preamp and the interconnects....and will check out Audacity....seems like I did that once a while back.
