hallow sounding center?
may sound strange but I was playing around with some things the other day. I hooked up my old CS2 for a center channel with my RTIA9's and watched a movie. Now I was just doing this to see what affect it would have I normally use the A6 for my center. Anyways....well I have my AVR set for small center and 5.1 surround with main vocals coming through the center.
but for some weird reason all the vocals sounded hallow to me, and were overpowered by the sound affects by the A9's..
So I went and boosted the center on my AVR moved it to large ect...still the same damn thing.
Now it seems odd to me this would happen seeing the CS2 isn't that much different in specs from the A6 but gave a completely different sound.
I just never noticed the hollowness of the voices, they lacked authority when I watched movies...
any ideas why this would happen besides its because I'm using a different model from the RTI line?
Post edited by cstmar01 on
Check to be sure the jumper between the terminals has not come off (assuming the speaker has a jumper). I had this issue when I got my CSi40 - replaced the jumper and I was good to go.
Good luck!
2-channel
Squeezebox Touch| MSB Analog DAC | Audio Research Ref 40 Anniversary Edition| Pass Labs X350.8 | Wilson Audio Sasha 2
Arcam AVR 550 | GoldenEar Triton One | GoldenEar SuperCenter XXL | GoldenEar Aon 3 | JL Audio Fathom F113v2 -
Good luck!
The CS2 acutally doesn't have a jumper at all, when I had originally bought it I thought it did have 5 way binding post but it doesn't.
I mean its just weird both have 6.5 woofers, the dome tweeter, about the same power handling 175 CS2 vs 200 A6, 90 for sensativity.
It just was strange that it would sound so hallow...like in just speaking passages I would have to crank up the volume just to hear it, but when playing the sound effects at that level would have to turn it way down...to me it seems like an AVR issue, but I redid everything and couldn't find anything. -
The CS2 isn't timbre-matched with your RTiA9s, the perfect match is the CSiA6, that's why it sounds "hallow". Why aren't you using the A6 anyway? When you set the crossover to small or large, it won't make a difference cuz it only filters out 100Hz-80Hz (and down) which is well below midrange.My system:
Front: 2xPolk RT800 Floor speakers (Bi-wired) - SOLD
Center: Polk CSi5 - For Sale!
Receiver: Onkyo TX-SR806 THX-Ultra2 130W 7.1
Sub: Velodyne DPS-12 -
I was just playing around with it, I had it sitting in my Bedroom which I was going to set up my smaller HT and wanted to see how it would sound with the A9's I realize its probably not the perfectly matched speaker but still to me should at least sound somewhat the same as what the A6 did.
I'm using monitor 70s in the bedroom so it'll be just fine in there but oh well. -
What's "hallow"?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Hollow.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Sorry I can't spell....hollow thats the word...doesn't help I'm trying to type really quick here at work and not using spell check...sorry...I know I look like a dumbass for spelling incorrectly but hey it happens.
LOL, that's why I put " " in between your hallow :-)My system:
hallow: to make holy, as in hallowed ground.
It's a real word so your spell checker would not have flagged it.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
did you have your receiver auto calibrate all your speakers? maybe they aren't calibrated.. and the front mains are to loud for that center.PolkFest 2012, who's going>?
+1, different tweeters in these two, and may be part of the problem.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
It's not that I'm insensitive, I just don't care.. -
What position is you CS2 in....? Is it near a wall or very far from one...? Are there a lot of reflecting surfaces in your room? Placement may be part of your problem? And what is it sitting ON??? Put it on something solid and firm.
cnh
Its sitting in the same spot my A6 sits which is about 2-3 feet away from the back wall sitting on top of a TV stand that is constructed of metal and glass and sits on a glass shelf. I have to "flip" the speaker so that it faces up to get a more direct listening position to the listener as otherwise the shelf it too low to have it flat and straight on if that makes any sense.
And acutally I thought they both used the same cloth dome tweeter, by looks the appear the same but I can be wrong. and acutally its more of the just pure vocals such as when someone is talking that creates the hollow sound not the tweeter as its coming from the 6.5 woofers.
It just struck me as strange that they would sound soo different.
and yes I did recalibrate, and then redid it, and then did a manual set up and even boosted the center by a couple places and lowered the L/R a few and regardless of what I do it still just sounds shallow to me, no real depth, which is strange as I used to use it with the Monitor 70's in the same set up and it didn't sound like this at all. -
I know those tweeters look the same but they are not. Will have to look at the specs on those speakers again..! In the M70 set up are the speakers 'closer to the wall' by any chance?
it is the same way how the Monitor series (Monitor 70) and the RTi series (CSiA7) sound different. They might have the same looking tweeter/driver, but they have different crossovers, internals, etc. If they sounded the same, then they would have to be priced the same... :-)My system:
