DSW Pro 1000 not sounding right
ikolbyi
ikolbyi Posts: 77
Setup:
Polk sub: DSW micro-pro 1000
Polk speakers: RM 85 (5.1 setup)
Receiver: Denon AVR-2809
Subwoofer volume set to level 14
crossover on receiver set to 100 Hz
crossover on sub set to max >200 Hz (letting receiver handle crossover, using LFE)
Issue, music (tuner/CD) sounds ok, movies (DVD/BlueRay)- the sub "walks" across the floor - way too much base - windows vibrate way too much.
The receiver is set to auto config sound levels and has the sub setting to -1 or +1 db depending on the movie or music. I manually configured the speakers during setup, because Denon had a hard time recognizing the speakers properly. I have another setup: Denon AVR-1909 with PSW350 + RMS2000 speakers (12 years old Polk setup) that sound and operate great in a much smaller room, again the Denon receiver didn't recognize the speakers at setup so I manually configured them.
Why is the sub so jumpy even when I lowered the volume to level 14 (level 20 is 50%)?
Room is hardwood floors with cathedral ceilings, 20'x24' size.
Zone 1
(5.1 Setup)
-- VM 20 (L/R)
-- RM 8 Center (center)
-- VM 10 (S.L/R)
-- DSW microPRO 1000 (LFE)
Zone 2
-- Atrium 45
Denon AVR-2809
(7.1 Setup)
-- RM 6600 (L/R + center + S.L/R)
-- RM 7 (SB.L/R)
-- PSW 350 (LFE)
Denon AVR-1909
Post edited by ikolbyi on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited January 2010
    It's jumpy because of the Passive Radiator on the bottom. Try putting a piece of carpet under it.
  • dorokusai
    dorokusai Posts: 25,576
    edited January 2010
    It's a highly motivated subwoofer.
  • danger boy
    danger boy Posts: 15,722
    edited January 2010
    just lower the volume on the sub till it stops jumping. I think if it's jumping.. it's turned up to high.
    Or put something heavy on top of the subwoofer so it stays in place. ;)
    PolkFest 2012, who's going>?
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    leroyjr1 wrote: »
    That seemed to work, but now it sounds as if their is less-base in the sound. I actually turned up the volume which did help, but it still sounds a little hollow.
    With no carpet, the sub is too bass-ey and if you turn the volume down, then movies sound great but not music. If I place a 12"x12" piece of carpet as you suggested, I need to turn the volume up but it does not have the same sound quality. Ho-hum. Any recommendations at this point? (fix one problem but create another.)
    Thank you for the suggestion.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • leroyjr1
    edited January 2010
    Try raising the sub off the carpet some by unscrewing the feet a little. This should give you more room between the carpet and the bottom of the sub and the bass should sound better
  • Serendipity
    Serendipity Posts: 6,975
    edited January 2010
    Place something under the sub. That should help.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    leroyjr1 wrote: »
    I raised them which game me about 3/4 of an inch. No difference.
    Would messing around with the cross over frequencies of all the speakers in the room make a difference in an attempt to compensate?
    Right now I have the following settings:
    Fronts (Polk RM 8) 100 Hz
    Center (Polk RM 85) 120 Hz
    Rears (Polk RM 7) 120 Hz
    Sub (Polk DSW micro-pro 1000) 100 Hz
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • leroyjr1
    edited January 2010
    Try dropping everything to 80 hz and see if that helps any. Other micropro owners with hardwood floors have tried adding some weight to the top of the sub to prevent it from jumping. I'm running dual micropro 4000's set at 80hz on carpet without any walking issues. Setting it up properly is the key to achieving good bass at the listening position. Play around with placement if that's an option.
    treitz3 Posts: 20,159
    edited January 2010
    ^^^Good advice^^^
    How close is the sub to a wall or corner?
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    4 feet. It's near (plus in front of) the main listening location.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • megasat16
    megasat16 Posts: 3,521
    edited January 2010
    I usually use DSW Micropro subs as foot rest or ottoman in the HT room. but sometimes, they jump. However, I found that no PSW micropro subs jumping after I put my 200+LBs **** on it.
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
    edited January 2010
    kolbtod wrote: »
    Well, that's not the issue. Let me ask you this......are you using any tone controls or does the auto calibration [or manual] boost the bass frequencies at all?
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    Auto calibration.
    I attempted to override the settings and manually set that up when I originally installed the unit, but Denon loves to reset it back to auto when you power off the receiver. Basically forcing you to always use auto unless you don't mind adjusting the settings every time you want to watch TV, etc.....
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
    edited January 2010
    You've GOT to be kidding me. There's has to be a way to set it and forget it. Man, if not, I feel for you. Wait a little bit. Maybe someone with knowledge of your AVR can offer a suggestion or two. In the meantime, see if you can't pull out the manual and see if there is something you can do about this. That particular sub does not need any boost of the lower registers.
    Oh, my manners......Welcome to Club Polk!
    edited January 2010
    What model AVR are you using for the sub?
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    treitz3 wrote: »
    In the original (top) post: Denon AVR-2809
    Auto sets the sub at -1 or +1 db depending on the show/movie. I read on another similar post the individual solved their problem by placing rubber suction cups under the feet of their DSW micro instead of carpet. I will try that....stay tuned.
    Thanks for the feedback and suggestions so far.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
  • rallyshark
    rallyshark Posts: 417
    edited January 2010
    You can:
    1. put small squares of two sided tape under the feet(scotch command can be removed without damage) <$5
    2. get a Auralex Subdude(about $50)
    3. build your own interpretation of the subdude for less
    4. not suction cups, they are just little cups that the feet can fin into which will make it harder for the sub to walk, but they are stuck to the floor .
    You are likely misinterpreting the vibrations for loudness. I did at first. Those things really send them on hardwood floors. See:
    http://www.polkaudio.com/forums/showthread.php?t=94172
    The sub will get better after break in as well. Also, try the different settings on the remote like corner/mid wall/ mid room/ cabinet etc. You may want to play with the phase settings to. Moving it around to different locations may help some to. But the fact is, unfortunately, that that passive on the bottom will send a lot of vibrations on a hardwood floor. Any thing you can do to get it off the floor or put something under it will help. The carpet will only help with the "walking" for the most part. It being too loud shouldn't be that big of an issue in a room that size. Don't give up on the sub. It's a great little sub after you finally get it set up right, but sometimes it's just harder to get right:) I think you would be a good candidate for a subdude IMO. I hope this helps:)
    Sony 40" LCD
    Sony DVPCX995V
    Sony PS3(games/media server)
    Sony PS2
    WD TV Live with 3TB
    Sanyo VCR
    Marantz SR6003
    Polk 11T(xover/RDO)
    RM20 5 pack
    OWM 5
    DUAL Micro Pro 1000
    Combastard Cable
    Harmony One
    When rapture comes, can I have your car?
  • dorokusai
    edited January 2010
    I'm not sure how severe it is but some Blue Tac adhesive for leveling pictures may work as well.
  • dabo
    dabo Posts: 9
    edited January 2010
    these are the rubber cups that I placed under my microPRO
    on my tile floor, available in Home Depot for $2
    another option instead of carpet would be a rubber mat, like
    a yoga mat type of material
  • ikolbyi
    ikolbyi Posts: 77
    edited January 2010
    rallyshark wrote: »
    You can:
    I had some small rubber pads/feet from an old computer that I didn't install. They are 1 inch in diameter and seemed to do the trick. I also raised the feet on the sub to max height lifting it a good 1.5 inches off the ground. Sound is good (back to normal) and distortion from vibration only occurred once during my demo when the base exposition was severe (very loud right in front of the viewer - Demo/trailer for Valkyrie)
    Thanks everyone for the help, problem solved.
    Note to self: If you plan on installing this sub in a room with carpet, purchase model 3000 (10") and not the 1000/2000 (8") since the carpet
    seems to absorb the sound and you will need the extra to compensate.
    Zone 1
    (5.1 Setup)
    -- VM 20 (L/R)
    -- VM 10 (S.L/R)
    Zone 2
    -- Atrium 45
    Denon AVR-2809
    (7.1 Setup)
    -- RM 7 (SB.L/R)
    -- PSW 350 (LFE)
    Denon AVR-1909
