New here, need help with first polks
saabracer23
saabracer23 Posts: 43
edited January 2010 in Speakers
Hello everyone, this is my first post here as I now own my first pair of Polks. I have owned quite a bit of nice vintage gear thanks to my dad. I havve just received a pair of sda II's. I have done a bit research and have not found much on this particular pair. The have 2 SL2000 tweeters, 3 midbasses and a 12 inch passive radiator. Most of the sda II's I have seen have one tweeter and two woofers. How does my pair compare to the other models in the sda II lineup?
I read that they removed the one tweeter because they found it pretty much useless, why did they remove the third woofer?
What can I do to improve the quality of the speaker? Replace parts, recap crossovers? Any tutorials or the like?
I must say I do like them alot, these replaced a pair of dcm timeframe 600's that my cats were using as a scratching post. Anyways any answers to my questions would be great.
Dan
Post edited by saabracer23 on
  • JohnLocke88
    JohnLocke88 Posts: 1,150
    edited January 2010
    Those are the SDA2 "original." A's were SL2000s, 2 woofers, 1 passive in a "studio styled cabinet" with wood veneer. B's were SL2000s, 2 woofers, 1 passive in a studio styled BLACK cabinet, or a cabinet with wood end caps and cloth grille paneled sides.
    The SDA-2s were good speakers. The extra tweeter was removed because of phasing issues with the stereo tweeter (or so I've been told.)
    The third woofer was removed simply because it was no longer needed (IIRC, in the original SDA-2, the bottom woofer did bass stuff, were the two groups of one tweeter and one woofer, were the stereo array and dimensional array respectively. (SOMEONE MORE KNOWLEDGEABLE, PLEASE FEEL FREE TO EXPAND / DEBUNK.)
    As to what to do to improve: replace the SL2000s with the RDO-194s, recap the crossovers, mortite the inside of the cabinets to decrease air leakage, etc etc.
  • ben62670
    ben62670 Posts: 15,969
    edited January 2010
    You nailed it John.
    Ben
  • JohnLocke88
    edited January 2010
    ben62670 wrote: »
    You nailed it John.
    See you stick around long enough in the vintage section and you learn a thing or two. I only wish I came here (EDIT: thought we were in the vintage section) BEFORE visiting the regular "speakers" section, I might never have left.
    BTW, thanks for the offer on the woofers, I've decided after reading a bunch of reviews to save the money on buying spares and instead doing preventive maintenance to my current drivers... oh, and build myself some DIY acoustic panels.
    EDIT: Oh wait, we are in the regular speakers section.... :confused:
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2010
    Welcome to Club Polk.
    Tony M Posts: 11,599
    edited January 2010
    Welcome to the club.Great speakers you have there.
    Did you get the interconnecting cable too?
  • hearingimpared
    hearingimpared Posts: 21,136
    edited January 2010
    Welcome to Club Polk saabracer23!
  • saabracer23
    edited January 2010
    Thanks a bunch for the welcome guys! Thank you for the suggestions on the improvements to make, I didn't get the interconnect cables, but it seems pretty straight forward. Large blade to large, small to small, I just used some 16 awg wire I had. The SDA's seem hard to come by, but I would like to get my hands on a larger pair. I really like the way they sound although it would be nice if they had a bit more bass, my sub takes care of that though. Also not a big fan of the cheap looking cabinet finish. It in no way effects the sound though, which is all that matters.
    Dan
  • saabracer23
    edited January 2010
    Here they are in their new home.
    edited January 2010
    I heard a pr. just like yours and with the subs ,your not missing too much at all. I can't speak for the bigger 8 mw SDA's but my friends' system with a sub turned on sounded close to my SDA-SRS2's almost to a tee.;)
    You really should try and get a real interconnect cable. I had distortion at times with my homemade one vibrating. Afterward, distortion minimised to other faults..
    Congrats on the purchase again. I realy like those.
  • saabracer23
    edited January 2010
    Thanks, I guess I'll look into getting an authentic cable, I figured it wouldn't make a big dif. I plan on taking out the passives and getting a look at the crossover, would anyone suggest replacing anything but the capacitors? I'll also seal the corners while I'm in there. Next stop is peerless tweeters...
    Thanks again,
    Dan
  • JohnLocke88
    edited January 2010
    Thanks again,
    Dan
    You mean RDO-194's? You might need to do some cut out modification as I don't think the peerless tweeter is a direct "drop-in" replacement.
    Also, there's a guy selling aftermarket blade/blade SDA cables on ebay right now for $35. Not the greatest deal, but hey, they look decent.
  • ben62670
    edited January 2010
    The peerless will not drop in in place of the SL2000's. Not only is it physically different, but the XO is very different. The resistors should also be changed with the caps. SB23 if you post your location you can get more help here;)
    Ben
    Ben
    edited January 2010
    Nice picks! They look like they are very happy in their new home!
    cnh
  • chandler9a
    chandler9a Posts: 878
    edited January 2010
    I bought that cable off ebay for my SDA 2A's and it works fine from what I can tell.
    Welcome to the Club, listen to these guys... they know what they are talking about:)
  • ScudDawg
    ScudDawg Posts: 68
    edited January 2010
    yeah sweet looking speakers
    Home Theater:
    Processor: Emotiva UMC-1
    Amps: Emotiva XPA-3, Emotiva UPA-5
    Center: Polk Audio CSi A6
    Fronts: Polk Audio RTi A7
    Surrounds: Polk Audio FXI A4
    Surround Rears: Polk Audio RTI A3
    Subwoofer: SVS 2039 PCi (upgraded woofer)
    Power Conditioner: Monster HTS 5100 Signature Series
    2 Channel: (work in progress)
    Speakers: Polk Audio Monitor 40
