Wich Subwoofer under 600.00 ?
I need a hard hitting sub for a 20x26 room. I am only using it for music. My budget is about 600.00 or so. Thanks .Is this possible ??
Post edited by Neale13 on
Sure it's possible. I would check out SVS or Hsu. Give them a call and see what they can do. That's a big room and would have to go bigger....but they also may have 'B' stock.
Another route is check out used stuff on Audiogon, Craigslist etc.... a lot of great deals to be had.Onkyo TX-NR809
Boston Acoustic VS 260 - Mains
Boston Acoustic Vr920 - Center
Boston Acoustic Micro 90 - Surrounds
Boston Acoustic HPS 12HO - Sub
Samsung LN40b650 - LCD Monitor
Yamaha Rx-v2200
Polk Rti 70 - Mains
Polk Cs245i - Center
Polk Rt/Fx - Surround
Boston Acoustics Vr500 - Sub
Optoma HD20 Projector -
Ive tried alotta subs and 1 of my MFW-15's will blow anything in its price range. Althought AV123 has had a shotty past they make the best for the money. bSTOCK SELLS FOR 499.00
right now a Moho Diamond MFW-15 sells for $399+130 shipping. a steal in my opinion.Onkyo 805, RtiA5s, Csi5, Rti6s
DSW PRO 600. using it in 18.5 X 28 room excellent bass
Heard 600 was a good performer. Specially with music. Have you thought about dual in such a big room? -
I like the DSW Pro 600 for music, I'm using it in a 20 x 32' + room and it sounds just fine. It also does a decent job for HT too.
Can you DIY? Do you have access to any tools such as a table saw and router?
Would you have the desire to DIY? If so then your options opened up considerably. -
yes i am thinking about a dual sub, but i am looking first to amplify my RTI A9s , their BASS extension might negate the need for a second sub. -
That's a two sub room up there. Suggestions for SVS, HSU and Velodyne are good ones..
If you're using 2 I'd also consider the Polk DSW-600. And give Elemental Designs a look--they're kind of the new kid on the block and offer a lot of power and value for the money.
Some people also run Epiks and Sunfire subs...
In any case. Start with ONE and save for ANOTHER!
cnh
i am finding eD getting more hype frankly (specially on the A3 and A2) i find the new POLKs (DSW) very competitive there, some people are facing some quality issues with their subs, not to mention the waiting. -
Sunfire True Sub. They can be had for your budget if you are willing to watch and wait on ebay and audiogon. I have bought two for under $500 each.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
http://www.hsuresearch.com/products/vtf-2-mk3.html
HSU subs are known to be very musical, and clean, while still being very powerful. I'd say they're the most musical subs on the market. Plus you benefit from the variable tuning capability. (close one port: tighten the response, and lower the extension.)
The VTF-2 fits your price range, and should have sufficient output for music in your room.My System Showcase!
Media Room
Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
Living-room
Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
Headphones
Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
