4 subs placement
primerib
Hi,
I have 2 PSW303's up front and I am now in the process of hooking up 2 PSW10's that arrived via mail order before Xmas and I have some time to do this. I plan on replacing the fronts with the 10's and move the 8's to the rear where my surround speaker are....or should I put them toward the front where my other ones are? Room is aprox 20X20 or more hence the reason I'm looking for additional oomf.
Home Theater: Pioneer Elite VSX-33TX AVR, Pioneer BDP-51FD Bluray, Polk M70 fronts, Energy C500 rears, Energy XL-C100 center, Polk PSW303 X 2 subs, Polk PSW10 X 2 subs, Sharp Aquos 52LC-E77UN lcd TV, Harmony One remote, AspenAceHD PVR
2 Channel: Pioneer VSX-709D, Polk M20 speakers, Mission 10" sub, Pioneer Elite DV-46AV DVD player, Sharp Aqous 42LC-D62U lcd TV, Harmony 550 remote
Garage (Vintage): Sears Professional Series Reciever, Marantz tape player, Marantz turn table, Infinity speakers
Hi,
it's best to put one in each corner (keep about a feet clearance between the subs and the corners). -
Thanks. This will get interesting considering how much sub cable I will have to buy.....but I'm sure it will sound pretty good even though these are really entry level subs.Home Theater: Pioneer Elite VSX-33TX AVR, Pioneer BDP-51FD Bluray, Polk M70 fronts, Energy C500 rears, Energy XL-C100 center, Polk PSW303 X 2 subs, Polk PSW10 X 2 subs, Sharp Aquos 52LC-E77UN lcd TV, Harmony One remote, AspenAceHD PVR
Garage (Vintage): Sears Professional Series Reciever, Marantz tape player, Marantz turn table, Infinity speakers -
Or in the middle of each wall (less reflections).polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Serendipity wrote: »Or in the middle of each wall (less reflections).
+1, forgot to mention that, also try to get/build rizers for your subs, u might find the result interresting. -
I've probably got 25 hours into re-positioning my 5 subs, the best set-up so far is a little "interesting" location wise, but the time spent with experimentation is well worth it.
.Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
HT-Denon avr3808ci,Carver a-753x,Panasonic ae4000 projector,120" screen,ps3,wii console w/full rockband,Panamax conditioner,dbx120 subharmonic synthesizer,jvc dvd-a player, Polk RTi12 mains,Polk CSiA6 centre, Energy ES-18xl sub,two custom 10" powered subs, Def Tech bp2x surrounds(4),Paradigm monitors-rear(2) -
I have lately read many posts that have two subs stacked. I thought conventional wisdom was to place subs towards the corners of a room. But the more I read about stacking subs the more I think I will have to give it a try:rolleyes: Might make it easier to set up properly.HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
Why wouldn't you just spend all that money on one really good sub instead of 4 "eh" subs?
There are some very good hsu subs out there for what you probably paid for those 4, that will probably outperform all of them combined.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
I have a 10" Mission sub (pretty expensive) that I tried down stairs without success....it is too big for 1 sub anyway you cut it, but I totally understand what you mean. I bought all these subs for about $600 and I will say that it blows away the Mission that I bought 4 years ago for $700. This room isn't quite square and larger than I originally said, and my problem is reflections unfortunately which I am trying to curb down with area rugs a different layouts.Home Theater: Pioneer Elite VSX-33TX AVR, Pioneer BDP-51FD Bluray, Polk M70 fronts, Energy C500 rears, Energy XL-C100 center, Polk PSW303 X 2 subs, Polk PSW10 X 2 subs, Sharp Aquos 52LC-E77UN lcd TV, Harmony One remote, AspenAceHD PVR
OK....I'll bite.:D What is your layout?Home Theater: Pioneer Elite VSX-33TX AVR, Pioneer BDP-51FD Bluray, Polk M70 fronts, Energy C500 rears, Energy XL-C100 center, Polk PSW303 X 2 subs, Polk PSW10 X 2 subs, Sharp Aquos 52LC-E77UN lcd TV, Harmony One remote, AspenAceHD PVR
I'd put them in respective corners of the room as well...and tweak from there.
OR..you could put them in the middle of the room right next to each other so that they form a bench seat and put a big cushion over everything...who needs a buttkicker when you're sitting on four subs? I am joking, of course!
Well, I'll explain it as best I can, but I'll post some pics as soon as I can take some without my wife calling me a complete dork. Room is 12' x 30'. Front sub is 18" energy between left front and center speaker.Sub#2 is a 10" jl audio hard against the right wall about 8' back from the front. Subs 3&4 are mounted in the 2nd row seat riser in a custom ported enclosure 12" jbl's. Sub 5 is hard against the left wall,under the bar, about 4' from the back wall,another 10"jl.
Believe or not the bass is very even throughout the room, especially in the seating positions. Took alot of time with spl meter in my hand and moving things around, but the difference is incredible compared to just "plunking" them anywhere.
Oh ya, it rattles your teeth...:D:DTwo Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
I'm new to much of this but from my understanding so far, conventional wisdom = stacked/co-located subs increase output, spread out subs work with each other to flatten out response.
Try to picture the sound wave as a large, low freq. (long) sine wave. It may be helpful to understand why placement is so critical to avoid nulls.
With different locations you can help fill the null from one sub, with the sound wave of another sub. So like cnh said a good starting point with 4 subs would be in the middle of each wall, or in each corner.
But as always no two rooms are the same so tweaking time is required. -
Sub hookup question. Currently use a Preamp Sony DA3100ES , Monster Cable Y splits the sub line level out to a NAD 925THX Power Amp. I use monster cable speaker wire to feed the 15" subs in each of my Klipsch KSP 400 main speakers from the NAD power amp. The speakers are bi-wired for the main l/r sound and l/r sub sound. I have a Sony SA-W3800 15" sub that WAS given to me as a gift. I would like to add the Sony sub on the back side of the room. Is it possible to split the line level feed again? If not, I have a Sony TA-E2000ESD preamp that is not in use. Can I pull it into the equation?
Mine goes from the subwoofer out on the receiver to the input on a dbx 120 and splits 5 ways. No issues, works perfect.Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
The dbx 120 splits the sub signal 5 ways? Is that a dbx 120A? Perhaps I should consider the dbx. -
No, the dbx doesn't do the splitting, the split is after it, just a wye at each sub.
I wasn't sure it would work either, but it's perfect.Two Channel-SDA SRS 1.2tl's,modded, Cambridge Audio 851w amps(2),Cambridge 851e pre, VPI Scout 1.1 tt, Moon audio phono pre,oppo bd105.
Thanks everyone for the info.:)
Well, thanks for all the advice....after about a week of tweaking I finally have it nailed down. A few things I discovered for those who are doing something similar to me...it might help or it might not;
-Set up your bass levels on your subs individually, turn them all down to 0 and one by one up the manual volume control in the back until they all are at the verge of distorting. I marked each subs with a whiteout mark so after they all were done I had an easy reference.
-Phase the rear subs to 180 degrees and leave the front to 0. This helped when you put the rear subs beside the rear surround speakers.
-I found my THX receiver will adjust the LFE perfectly and set the speakers up at the best X-over setting when running analog from the bluray...the only thing I had to adjust was the speaker/sub outputs with the remote until it sounded right.
-Get a friend to help with the sub angle adjustment. I took the advice from another member here and found that all the subs were at different angles because of my bad reflections. 2 large area rugs helped tone them down considerably....curse those laminated floors in the basement for that one!! After a few days and some brews it all came together nicely.
All in all, sounds pretty darn good even with those PSW10's I have to admit.
BHome Theater: Pioneer Elite VSX-33TX AVR, Pioneer BDP-51FD Bluray, Polk M70 fronts, Energy C500 rears, Energy XL-C100 center, Polk PSW303 X 2 subs, Polk PSW10 X 2 subs, Sharp Aquos 52LC-E77UN lcd TV, Harmony One remote, AspenAceHD PVR
You could go a foot or so on either side of the keel centerline and still be fine. Make sure the transducer centerline is parallel with the waterline and not the hull.
