My Excellent Adventure
heiney9
On 11/22 I recieved a Dared VP16 integrated tube amp. Upon opening the box the shipper failed to pack the very heavy item properly and there was some damage. (2) Rear binding posts were bent as well as some chipping to the piano finish. The seller was very responsive and sent me a partial refund and I went on line and bought the exact replacement binding posts.
I had to wait a couple weeks for shipping from China but they arrived safe and sound. The amp came with new production JJ/Tesla 6V6S power tubes and Tung Sol 6SL7GT driver/input tubes. I was not impressed with these tubes so I purchased (6) 1950's RCA grey glass 6V6GT power tubes and (2) pr 1950's RCA "red base" 5691 (military 6sl7GT) input/driver tubes.
What an AMAZING difference the NOS RCA tubes made. One problem is this amp, in order to keep the output power high, is a manual bias unit. The previous owner either wasn't aware or didn't care. So while performing the repair we decided to check the bias for the JJ/Tesla and then install the RCA 6V6's and bias those.
The bias voltage should be 200-250m VDC. The JJ's tested between 160-175m VDC. That's quite a bit under biased. Put in the RCA 6V6's and biased each of the (4) at 220-225m VDC. Each has it's own bias pot/resistor and measuring point.
My good friend Aaron who lives close and is part of our little local audio group has the iron and a bit of know how so he performed the binding post repairs while I "supervised" Here are some photo's.
The damage
Inside/Bottom view
During and after the repair
For once reading the directions before rather than after........
Setting the bias
I got home late last night so I haven't heard it yet, but we did let it run on a small pair of Polk bookshelf speakers for about an hour and then re-checked the bias to make sure. Only one tube had drifted a bit.
I had fun!!!
The damage
Inside/Bottom view
Setting the bias
I had fun!!!
Post edited by heiney9 on
It's dangerous to bias the tube amp like that.
J/K. I am glad you had fun.
Happy Listening!Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin: -
I have to bias my Welborne ST-70 the same way, what a PITA!
Glad it all worked out for you."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Didn't even realize Rob was taking video. Technology is everywhere and you never know who's doing what, when.
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/cdhNyFhWcSM&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/cdhNyFhWcSM&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
I have to say this amp sounds absolutely superb with my 5B's. The RCA tubes are magnificent and I can see why the RCA 5691 and RCA 6v6GT grey glass, black plate tubes are being hunted into extinction. What an open, creamy, velvety smooth sound this amp has.
I am loving the sound!!!!
Looks like fun. Glad you guys got it up and running again.
PaulyLife without music would♭ -
Congrats Thanks for sharing.engtaz
All hail A2, master fixer.
Good to hear you got the binding posts replaced Brock. You sure did a nice job of cleaning up the exterior of the Dared. It looks pretty kewl lit up.
A McAlister PP150 I owned had to be biased from the underside with the cover off. My pinky strayed while adjusting and I got bit good.Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
Yeah, the bias procedure while simple is a bit of a PITA. Dared explained they kept this amp manual bias to keep the output wattage up. They felt by adding auto biasing it would loose valuable horsepower. It's not a big deal as these 50's RCA 6V6's are superb and I don't plan on doing a lot of tube rolling.
This thing is incredibly sweet!!! I can't get over how high, deep and wide the sound stage is, as well as how lush and full everything sounds, but at the same time every instrument and voice has it's distinct place with pinpoint imaging. No sloppy bass or rolled off highs; and mids to die for..............creamy, lush!!!!
This was shipped from the previous owner with JJ/Tesla 6V6S and (new production) Tung Sol 6SL7GT and while it sounded pretty good, it now sounds fricking fantastic. A perfect match for the modded 5B's.
I am absolutely thrilled!!!
I have to bias my old VTL's with the bottom cover off,,,it's a pita too,, but when set/adjusted properly,,the payoff is so good,it outta' be against the law.;)JC approves....he told me so. (F-1 nut)
george daniel wrote: »I have to bias my old VTL's with the bottom cover off,,,it's a pita too,, but when set/adjusted properly,,the payoff is so good,it outta' be against the law.;)
+1000
All the caps and large resistors have insulation on all leads ala Auricaps so while caution is still necessary, if a probe slips and touches a resistor or cap lead it's less likely to cause any type of catastrophic event
This newer version has actual probe points on the PCB, on the earlier model one had to measure across the resistor leads :eek:.
P.s. I hate to say this but sometimes I enjoy this little office rig better than the main rig!!! Something about the intimacy of a lower powered tube amp and smaller book shelf speakers in a smaller space. Sometimes I swear the group or singer is right here in the room with me
Near field can be a lot of fun. Treat the first reflections and you'll get a "headphone" effect."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
