Just wondering
I have 2 60's and 2 50's and am wondering if RM8 center will work. Reason for it is I have a big cabinet with a small opening and the RM8 will fit. I also have a PIONEER vsx1019 to power it. I have not had time to hook up.
Post edited by ddbonzey on
Sure, why not?polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Welcome to Club Polk ddbonzey!
What about the CS1? It's not as good as the center I would like to recommend to you (CS2) but if space is an issue the CS2 is not going to be an option for you as it is a beast. If not I would imagine that the RM8 would work? Welcome to Club Polk.
-JeffHT Rig
Receiver- Onkyo TX-SR806
Mains- Polk Audio Monitor 70
Center- Polk Audio CS2
Sub- Polk Audio PSW125
Blu-Ray- 80 GB PS3
2 CH rig (in progress)
Thanks checked those out and has to be no wider than 17inches....
Welcome to the Club (Polk)!
I say find a way to mount a good center speaker. Do not compromise the quality on this, it is the most important speaker in an HT setup. Can't you make a wall-mounted stand to place it in or something?My system:
Front: 2xPolk RT800 Floor speakers (Bi-wired) - SOLD
Center: Polk CSi5 - For Sale!
Receiver: Onkyo TX-SR806 THX-Ultra2 130W 7.1
Sub: Velodyne DPS-12 -
The RM8 would work, but it will have a hard time keeping up with the other speakers in your HT. You will have a hard time hearing the dialogue and voices when you are watching movies. You could just turn the center up and the rest of your speakers down, although I wouldn't recommend it. IMO, try to find a way to use a better center, or find a new cabinet that'll fit a CS1 or CS2. Good luck and welcome to CP.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Thanks for all suggestions, until I have time to hook up I will not know. once I do i will let you all know.
