Logitech Harmony 610 opinions
edbert
I was looking at buying this locally used. I have heard of a lot of people with different Harmony remotes but I wondered if anyone here owned one and what they thought of it. We got a new TV for Christmas and since I am going to have to change up the wiring, I need something a little more simple for my wife, parents and inlaws to use if I am not there. If this isn't a good one, any suggestions on other Harmony remotes or other all-in-one remotes I should consider I would appreciate it.
On a similar note, if anyone has a Harmony remote they may want to sell, PM me.
Thanks!
Thanks!
I know just enough to be dangerous, but don't tell my wife, she thinks I'm a genius.
Pioneer VSX-816
Monitor 40's - fronts, bi-amped
Monitor 30's - surrounds
CS1 - center
PSW10 - I'll let you guess
Blue Jeans Cable - speaker cable
Daewoo 27 incher - one step up from a console
Sony Progressive scan DVD
XBOX
SOPA since 2008
Here's my stuff.
Pioneer VSX-816
CS1 - center
XBOX
SOPA since 2008
Here's my stuff.
Post edited by edbert on
I have had 3 Harmony remotes and currently own the 880. They are very good remotes for the money. I can't say I have used the 610 but have used the 676 which looks very similar. My wife couldn't live without it with the system.
Occassionally you can get refurbs of the 600 series for 35 bucks on buy.com.
shawnShawn
AVR: Marantz SR-5011
Center Channel: Polk LsiM706c
Front: Polk LsiM703
Rear: LSI fx
Subwoofer: SVS 20-39pci
DVD Player: Sony PS4 -
It is a good remote for the money.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Shawn, Have you had any problems with the 880 battery/ charger?I have had 3 Harmony remotes and currently own the 880. They are very good remotes for the money. I can't say I have used the 610 but have used the 676 which looks very similar. My wife couldn't live without it with the system.
shawn
I was thinking about getting one, mainly for the rechargable battery option, since my 550 kind of burns thru the batteries... thanks
PS: Sorry for the thread dropping
Yeah, but it is a very easy fix. They made the battery compartment too wide so over time the battery loses connection with the terminal. All you have to do is wedge and index card between the side of the remote and the battery and problem is solved. They gave me a spacer as well, but the index card has worked for over a year so I left well enough alone. No problems at all otherwise.
ShawnShawn
Front: Polk LsiM703
Rear: LSI fx
thanks Shawn, I have read about the "matchbook" shim.
