bridging a Carver AV-505
domflane
I just got a Carver AV-505 amp for my HT, but I want to give mt RTiA5's a little more power than the 80 wpc that it offers in five channel mode. Can I bridge this amp? I know that you can bridge most stereo amps, but this one is a little different than I'm used to. Thanks,
Dominic
Dominic
RTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 3
Polk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Post edited by domflane on
Well, in truth you can't bridge most stereo amps.
That said, if your amp can be bridged, there will be a switch (usually on the back) that allows you to operate in bridged mode. However, since it's a 5 channel amp, not a 2 channel amp I don't believe it can be bridged.
I found this info....Carver AV505, it's rated at 80x5 with power steering. it can steer up to 130 watts into any one ch. at a time. Also rated at 100x2, all into 8 ohms.
That would indicate that you cannot bridge it.Political Correctness'.........defined
President of Club Polk -
I know the AV 806 can be bridged but I don't know about the AV505. If I were you I would bi amp with it if your speakers will do that. That is a pretty good amp and will power most speakers in most HT with no issues.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Thanks guys, I think I'll give bi amping a shot. My rear speakers aren't really worth amplifying, so that leaves me two open channels. My new question is, do I have to split the signal coming out of one of the pre amp outputs to use two of the amps channels to power one speaker?Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Yes you will have to by Y IC's to split the signal to each of the channels on the amp.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
Thanks for the help, now I have to try to find some decent Y IC's and some bi-amp speaker cables.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
