RTIa5 Vs RTI10
Hello all Polkies !
I'm completing my 7.1 (polk) setup and I'd like to have an advice concerning my fronts.
The room is 15x30 and dedicated to HT. The whole system will be powered by a pioneer 1019 amp, center's a CSIa6, SL/R and SBL/R are all RTIa5 (I know it's kind of overkill, but I got them über cheap ...), sub's a PSW111 (might upgrade to a velodyne VDR12).
Now, the local AV store has the RTI10 on sale for a little more than my RTIa5 ... would I be wise to switch ? Would I notice any difference ? I have found no comparison whatsoever between the two models, so any input would very much appreciated !
Thank you all for your time !
Post edited by Cabal05 on
You want to switch all of your surrounds to RTi10's? Or are you looking for fronts? The 10's are bigger and would be better for music, but they won't really match all of your RTiA's in terms of appearance. I would stick with the A5's for fronts, most here will say they're better for HT anyway. I have them and have no complaints for HT or music. Go with the Velo too if you can swing it, you wont be dissapointed. Congrats on an awsome HT rig. Good luck and welcome to Club Polk.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
Welcome to the club...
Personally i would not upgrade to the 10's. If this is a dedicated HT like you said would definitely need a better sub. I would spend the money on the sub, maybe 2, then see how things sound. I would stick with the RTiA series so they all look the same. You have a great system going and I dont think the 10's would make a big improvement really.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110 -
Do the RTIa series sound different from the RTi series? Can a CSi5 center timbre-match with say RTia7 fronts?My system:
Front: 2xPolk RT800 Floor speakers (Bi-wired) - SOLD
Center: Polk CSi5 - For Sale!
Receiver: Onkyo TX-SR806 THX-Ultra2 130W 7.1
Sub: Velodyne DPS-12 -
Thank you for the warm welcome
I'll stick with the a5 and buy the velodyne. Upgrade soon on my first impressions
I just picked up that VDR-12, I can attest, it's SICK. Love it. -
Welcome to the Club!
The RTiA5 is a good choice.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
RTi A5's paired with a good sub is the way to go.
