So, I'm going to build a new interconnect and need suggestions
mopar paul
mopar paul Posts: 277
edited December 2009 in Vintage Speakers
Title kinda says it all. I'm going to build a new interconnect for my 1.2TL's. I have done all the crossovers and tweeters and am upgrading all my stuff. The factory interconnect was long gone, and the one on it now uses RCA plugs and coax style cable, I think I can do better. I have been looking at Cardas cables and can buy their speaker cable in bulk, so I was thinking of using this, but my main question is how would you experts terminate the ends? RCA, binding post or other? I have all the ability and tools to do anything, so any option is open. Thanks for your input!:)
Post edited by mopar paul on
    F1nut Posts: 52,000
    If you can manufacture pin/blade ends that look close to and function as the original Polk ones do, yet allow one to use any cable with them, I'll be your new best friend.
  • mopar paul
    Actually I might consider that, I do quite a bit of fabrication but it never crossed my mind.
    F1nut Posts: 52,000
    If you pursue the idea and need some help, like an original sample, let me know.
  • TSWisla
    TSWisla Posts: 446
    I have extra pin/blade cable ends. BTW what is wrong with just using a cardas bp and a bannana or a spade?
    Zu Soul Supreme
    Coincident Frankenstein mkIII
    Esoteric K-07
  • mopar paul
    I dont think theres anything wrong with the banana ends so thats what I'm going to do, but obviously with much better wire and ends than polk provided originally.
    F1nut Posts: 52,000
    Banana plugs do not fit the pin hole.
  • TSWisla
    TSWisla Posts: 446
    Of course! I replaced them with a new bp.
    Zu Soul Supreme
    Esoteric K-07
    F1nut Posts: 52,000
    TSWisla wrote: »
    Yeah, I've seen folks do that. I will not be one of those folks.
  • TSWisla
    TSWisla Posts: 446
    Tell me why, did I make a bad choice? Are you simply trying to keep the speaker as "original" as possible? I really value your input.
    Zu Soul Supreme
    Esoteric K-07
    F1nut Posts: 52,000
    It's just me being pigheaded.
    heiney9 Posts: 25,497
    The other option is to intall a female binding post in the terminal cup to accept the banana plug ends from your new cable. This is how my 1C's were modified. The only downside is when/if I need to use the AI-1 interconnect (for mono's or non-common ground amps) I'll need to do add'l modification to accomodate the AI-1.
  • SoundEsc
    SoundEsc Posts: 10
    Just built one today following the instruction in This thread.
    My parts list (mostly homedepot) is posted at the end of the thread.
    My current HT 7.1 Setup:
    Fronts: Polk SDA CRS+ (4.1TL)
    Center: Polk CS2
    Front Heights: Polk R15
    Surrounds: Polk RC80i
    Sub: Polk DSW MicroPro 3000
    Projector: Optoma HD72 w/ 100" screen
    Receiver: Onkyo TX-SR707
    HTPC: Vista Ultimate
    BluRay/Game: PS3
