Help with amp for speakers
27wsc
27wsc Posts: 5
edited December 2009 in Speakers
Hello every one happy holidays. I am a confused, new to the separate amp for speakers, person. I have polk lsi 25's, like loud music and of course to use with tv. My problem is their rated 300 wpc polk says dont go above 250 wpc however i see other people using amps with a lot of power to drive their speakers. Anu suggestions would be appreciated thank you
Post edited by 27wsc on
  • superjunior
    superjunior Posts: 1,632
    remember the LSIs are 4 ohm so if your not using an amp now and your avr isn't up to par be carefull with the volume. a good amp with at least 200wpc should do, but more juice usually = better sound.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • coolsax
    coolsax Posts: 1,826
    most people on here say the more power you give the LSI's a lot of the time more they sing so if you go over 250 wpc at 4ohm... you'll probably be alright.. you'll probably blow your ears before before you blow the speakers by over powering them.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    coolsax wrote: »
    +1, put 1000W to those LSi's, you will blow out your eardrums before you hurt the speakers. Underpowering your speakers will hurt them more than overpowering them. LOL, having said that, just be careful with the volume knob.
    -Jeff
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • Krazyz1
    Krazyz1 Posts: 256
    More speakers are damaged being over driven with too small of a amp. BUT just lost a crossover on a RTiA9 using a ROTEL RB-1090-( 380wpc. ) Haven't figured that one out yet. Under warranty. Need to call Polk in A.M.
    tonyb Posts: 33,068
    ...being over driven,period. If your ears aren't good enough to tell you the limits of your speakers,your wallet will in repair costs.
  • jimreeves
    jimreeves Posts: 57
    27wsc wrote: »
    Welcome to Club Polk!
    IF you're using your LSI's with a AV receiver that has preamp outs for the front speakers you may want to look for a vintage stereo power amp to power them. I use a Yamaha P2200 pro power amp in my setup, it specs right up there with home audio amps at a fraction of the cost per watt per channel and shows up regularly on the 'bay. Plus there's no fan to add noise, just big friggin' heatsinks.
    Infinity QLS1, Polk SDA-1A, OLAdvent Econowave, Yamaha RXV-1300, CDC-685, P2200, AB International 9220A, Rane ME15B, Cambridge Audio 640P, Grant Fidelity B-283, Luxman PD277-AT7V, Pioneer PL707-Denon DL-207, DL-160....And projects on the bench!
  • superjunior
    Krazyz1 wrote: »
    just did it..
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    tonyb wrote: »
    and this is why..
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • Krazyz1
    Krazyz1 Posts: 256
    In my particular case I have clipping lights ( that were not lit up ) also have peak lights on my SAE 2800 ( wich were not lit up ). My rule of thumb correct or not when the vocals are starting to distort and can't quite understand the words , I back the volume down till the clarity is regained. If some one has a better procedure , I am open for suggestions. Very well stated Mr. tonyb.
