starting a two channel system
dfledezma
dfledezma Posts: 148
edited January 2010 in 2 Channel Audio
Hi everyone and happy holidays!
As I read in other post, I should keep myself away from this forum!!! hehehe :p
I just finished the first part of my audio system, I put together a humble system for HT and music, comprised of TSi300 at fronts, TSi100 for rear and a CS10 for center, a velodyne DLS400R, powered by a Denon AVR790, PS3, and a 46 in Panasonic plasma.
I plan to leave this system as it is now, or maybe adding two more speakers for 7.1 setup if I can move this to a bigger room. At the moment is an all purpose setup.
However, I would like to start a two channel system in a more "purist" way just for music and using separates. I'm not sure where to start, so I'm looking for some guidance. I don't have a defined budget now but I have some ideas of what I want. To begin with, I want to keep the cost reasonably low (who doesn't), I'm not planning to get the super high end system.
My first question is about the speakers. I would really want to get a pair of LSi25 or 15's. For what I've read in this forum these are more musical, and the RTia's are more suitable for HT. However these are a bit expensive. Maybe LSi9's. I'd like the 15's or 25's because I don't want to get a sub. What other speakers in this price range or less do you recommend for music?? I mostly listen to all types of rock music, and a bit of classical, jazz and blues.
About the amplifiers, I've learned that emotiva is a good brand offering reasonable price tags. Is the UPA-2 to low for what I want? Or is it better to get the XPA-2. I've also read that outlaw is another good start, am I wrong?
I still don't know to much about preamps yet....:confused:
Many thanks in advance, I really appreciate your advice.
  • kawizx9r
    kawizx9r Posts: 5,150
    edited December 2009
    You'd be making a good choice if you go with the LSi's. I just picked up a pair and actually had a chance to grab LSi9's (used at a hi-fi shop) for as much as 7's (new) but went with the 7's because I've read several threads about a mid-bass hump in the 9's and the fact that the 7's sounded a bit more balanced. Got them up on some nice stands and they sit perfectly at ear-level, paired with a micropro I'm in 2-channel heaven :D
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • dfledezma
    so, correct me if I'm wrong. An integrated amplifier contains both pre and power amp? I didn't know about that but sounds like a good idea. I still have much to learn in this world.
    BTW when I did my postgrad in UK, I remember they used a lot of Cambridge audio equipment. Well it was the sound and vibration research institute, so I suppose they're good. What do you think of Cambridge audio?
  • mshan242700
    mshan242700 Posts: 823
    There are probably a fair number of reasonably priced, high quality integrated amps from various manufacturers.
    If you like the Paradigms, might want to check their website for local dealers and see what type of package deal they can offer you.
    Decide upon an approximate budget for speakers and integrated (don't know if you are also looking for a cd player or dac), take some cds of music that you actually like to listen to, go see what they say and recommend, and listen with your music trying to approximate how you would use system at home.
    Good luck.
  • concealer404
    concealer404 Posts: 7,440
    You'd want a sub with the Atoms...
  • Conradicles
    Conradicles Posts: 6,434
    Here is my suggestion for a nice starter system:
    NAD Integrated amp
    NAD CD Player
    Polk Audio Vintage Monitors of your choice (maybe Monitor 7's or SDA-CRS+)
    SignalCable speaker wires and RCA interconnects
    Then you could upgrade in the future. Peace.
  • AudioFilet
    AudioFilet Posts: 235
    LSi's are a good choice for your new system, but you will need a good amp to drive them. Some people in this forum will tell you that you need gobs of power to run them, but I have found that this is not necessarily the case all the time. I have had my LSi9's for about 3 years, and powered them from a variety of equipment (I do have some disposable income for this hobby). You just need a quality amp to do them justice. I have run them just fine with my Outlaw RR2150 & a HK 3480. Right now I am using an Emotiva USP-1 preamp and UPA-2 amp, and it all sounds great. I was very pleasantly surprised by the Emotiva equipment. I took the covers off of them to check things out. Build quality appears to be quite good, with thoughtful layouts and good quality components. Very respectable stuff, especially at the prices they fetch. Pretty hard to beat at those prices.
    I will be replacing the USP-1, but not because I am dissatisfied with it. I just really like the Parasound 2100, and want to give it a run. I'm going to pair it up with an Emotiva XPA-2 and see how that works. Hopefully the Parasound/Emotiva combo will work well together & I won't need to buy the much more expensive Parasound amp.
    My next upgrade after that will be to replace the LSi9's with the LSi15's to see if I can lose the subwoofer.
    Hope some of this helps, and good luck with your new system.
    2 Channel rig:
    LSi9"s (modified xover's) & HSU Sub
    Harman Kardon HK 990 Amp
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
    HK AVR-745 & Polk Monitor Series
  • dfledezma
    Thanks to all for the advices. I'm still new in the audio world.
    I'm very tempted to get he Emo UPA-2, after reading from Audiofilet who uses it, indeed the price is more than reasonable. I'd like to get the USP-1 as well. Still considering the nad's too, I have some time to decide as I need to save up a little money first...
    I have another question. Can I use the zone 2 preouts from my denon AVR790 to drive the UPA-2? I'm asking this because I want to get the amp and speakers first. Then save a bit for the preamp which is a bit more expensive.
    Do you think the RTia series is good for music? I really like the LSi's but apparently there are good deals for the RTIa's. Anyway, I could wait to save more money for a pair of lsi's, just want to know what do you think. Of course I would like to get my hands on some vintage polks..
    Do you have any plans for your USP-1. I travel more or less often to San Antonio, just in case you want to sell some of your equipment.
  • Face
    Face Posts: 14,340
    I would not pair RTiA's with EMO gear for music, I would consider a NAD or Marantz amp/integrated or different speakers.
  • Zitro
    Zitro Posts: 864
    NAD Integrated amp
    NAD CD Player
    +1, I did a fair amount of research before I bought my first 2 channel setup, and talked with a friend of mine, who has a very high-end 2 channel LP setup. He steered me right to NAD stuff (that's where he started too) and after auditioning it I was sold. Musicality and dynamic range are top notch in the price range, and they are built like tanks. They can be had for cheap if you shop around, and the quality is far beyond any mass-market stuff and excellent for the price. As you can see in my sig, all my components are NAD. I have yet to hear an integrated solid state amp that sounds as musical as mine in its price range (or even a bit higher than its price) and I only paid $240 new for it.
    NAD makes great entry level integrated amps and CDP; shop around and you wont be disappointed! I also listened to Rotel, Marantz and a few others but none compared to NAD for musicality imo. My NAD integrated will be the last thing I upgrade in my setup.
    As far as speakers go, the options are so far and wide a debate on the best could go all day. As cliche as it sounds, you really would just have to listen for yourself! Were you thinking bookshelves or towers? Check CL for speakers, you will be amazed at some of the things I've found there, people not knowing the value of what they're selling.
    - Jeremy
    Amps: Jolida FX-10, NAD 3045, NAD C320BEE, Sansui G-9700
    Speakers: Polk Monitor 7A's, KEF Reference 104aB
    Sources: ProJect Debut Carbon, Sonos streaming FLAC
  • turbopantera
    turbopantera Posts: 35
    I am glad to see someone else on this forum also likes NAD. I have found their cost/value relationship to be very good. Yea, There is better, but you have to spend many times more to get it. Personally, I cant afford $5000 monoblocks. If you dont really like the integrated amp idea and want seperates. Think of some of the older NAD. Such as a 1600 pre and a 2600 main amp. Easily picked up on Ebay for around $500 for both.
    Dave
    In love with SDA since 1984
    2CH: SDA SRS (new caps) with NAD 541I, NAD 917 and modded Phase 400 (soon to be NAD 208)
    HT: SDA 1C (new caps, SL2500s, bass mod) with NAD T763 and Monitor 4 as surround
    Other vintage stuff, Sansui G9000, Pioneer 1980
  • concealer404
    Face wrote: »
    Mmmmm...... forward in your face speakers paired with forward in your face gear.
  • dfledezma
    I really like the idea of an integrated amp, is just that they have moderate power ratings, and whilst they surely be enough for what I want, I would like to have some headroom if for example I get a more power hungry speakers..
    Anyway, I'm researching more about NAD and seems like a good option, still have much time to think.
    What I will need for sure at some point is a DAC since I listen to CD's and my macbook pro using the optical out. Any suggestion on these?
  • organ
    organ Posts: 4,969
    There's nothing wrong with using the RT line for music. I like my RT1000's for 2ch just as much as my LSi9.
  • madmax
    madmax Posts: 12,434
    Personally when I had the LSi15's and LSi7's and LSi9's and compared the three I found the LSi7 with a good quality high powered amp the most enjoyable for 2 channel listening. The amplifier I used was a 350wpc Soundcraftsmen amp but there are many high powered choices out there. Of course a decent source is a requirement for any good 2 channel setup. In case you are worrying about high power any of the LSi's mate well with clean ultra high power. The danger comes in when the power is too low which in my estimate is below 200wpc where you could possibly clip the signal and cause damage trying to make louder. Sorry, more info than you asked for. :)
    madmax
    Vinyl, the final frontier...
  • concealer404
    organ wrote: »
    Those are a bit different from the modern RTiA series. ;)
  • dfledezma
    Face wrote: »
    Ok, I know that emotiva discussions could be dangerous, and I don´t want to start a storm, and forgive me because I´m still a newbie. But what exactly do you mean? that RtIa´s are to good for emotiva? or the opposite?? Or just that the combination would not be good for music but for HT, for example?
    At the moment I´m very tempted to get a pair of RTi A9 or polk direct, the price is very good. What amplifier do you recommend? I want to stay at about 500 USD new if possible. The only way I would buy used is from someone with good reputation.
    please don´t shoot me if this budget is to small for a decent amp, I might upgrade it later.
  • Face
    Face Posts: 14,340
    I'm not bashing either. They're both known to be forward, so depending on the rest of your associated gear, they may not be a good match for two channel listening. That's all. :)
  • thuffman03
    thuffman03 Posts: 1,325
    If you are going to go with the LSi's I would go with a used Sunfire or Adcom. There are a lot of used amps that will power them well. IMO the more power the better. You might even want to think about a 5 channel amp and bi amp them. Just a thought.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • rcrook317
    rcrook317 Posts: 280
    Face wrote: »
    Why is this? would like to hear specifics as im running rti12s and am 2-3 weeks from purchasing emo gear,prob a xpa-2......
    fronts=rti12s(cherry)
    center=csi3(cherry)
    sub=psw125(cherry)
    emotiva xpa-2
    harmon kardon 354
    sony cdp
    ipod 8gb
    audioquest diamondback 1m
    "Maesto" straightwire cables
    pangea ac-9
    playstation3/120gb=blu-ray/media server
    monitor=lg 55inch lcd(1080p)
    TT Set-up=Pro-Ject RM 1.3
    Kenwood Phono
    bren1 Clamp
    Herbies Slipmat
    "It doesnt mean that much to me,to mean that much to you"
  • concealer404
    rcrook317 wrote: »
    That's a little different. The RTiA series are pretty bright and forward. Pair bright and forward speakers with very bright and very forward gear, and you end up with ear-splitting very fatiguing sound. At least to my personal ears. YMMV.
  • tugzy
    tugzy Posts: 46
    edited January 2010
    delete
    Polk RTi A9, Polk CSi A6
    Paradigm Sub, Side, Rears
    Emotiva XPA-2, Pioneer Elite VSX-01TXH A/V 7.1
    LG BD390C BR, LG 60PG60 Plasma
    Hotaudio DAC Extacy
    XPA-2/RTiA9 in Action
    http://www.youtube.com/watch?v=-rtxxb2RIws
    http://www.youtube.com/watch?v=bgWk-fCAooo
    --vintage--
    Sansui G-7500 Pure Power DC receiver
    Sansui SP-X8000 4way/6driver speaker
    Sansui SR-535 Turntable
    Cerwin Vega AT-12 < Bud Beer
  • dfledezma
    edited January 2010
    thanks again for your advice.
    Another question came to my mind.
    I was thinking in getting a more powerful amp, or maybe two monoblocks, since I read that Emotiva is launching a UPA-1 model, and get a pair of TSi500 instead of the Rti A9.
    What do you think is better for a start? To have better speakers or a better amp. I mean, I now I can upgrade later, though I don´t think I´ll upgrade in a year or so.
    The LSi´s are a bit out of my budget, I´d need the 15´s or 25´s because I don´t want to add a sub.
  • Conradicles
    edited January 2010
    Better speakers without a doubt.
