3 channel amps
NeilGabriel
NeilGabriel Posts: 1,487
edited December 2009 in Electronics
I really need more power to run my system (currently a Denon 3802) because the HT room is a very large rec type room. If I get a 3 channel amp (200 w) to run fronts and center, and use the current receiver for rears, will this give me the power I am looking for or will I still be straining the receiver to run the rears?
Thanks.
  • ben62670
    ben62670 Posts: 15,969
    You will be fine. Remeber that most speakers are 88-93db at 1 watt/meter. Taking some load off the receiver will help the rear channels keep up.
    Ben
