Difference between M10, T15, R150???
edited December 2009 in Speakers
Is the only difference between these 3 how you mount them? Specs are pretty much identical.
Post edited by lmacmil on
    I can tell you that the T15/R15 use a different tweeter than the R150's. I have both, and prefer the tweeter on the T15 myself. I find the R150's to be lacking in high end, but I suppose some might find the T15's to be to harsh.
    At any rate, I can suggest that if you're trying to match, try to match the tweeter. In my case, I'm using 2 - R50's, a CSM, and 4 - T15's in a 7.1 system, and tweeters are all the same in those. If I'm not mistaken the R30's also use the same tweeter.
    On the other hand, if you want to match the R150's tweeter, you'll need to use R300's and a CSR center.
Welcome!
Welcome!
