rti's for a small living room
Hi..I'm trying do decide between the vm 20... and rtia1 csia4 surround sound for my living room...I'm goin to be using the denon avr3806 to drive them..looking for thoughts and pics of these wall mounted
Theater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Living Room: Panasonic TCP58VT25, PS3, Energy FPS, Onkyo Tx sr707, Sony Ps3, DswmicroPro 2000
Bed Room: Panasonic TCP50x1, Samsung Bd c7500
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3
Post edited by eclimax13 on
I'd go with the RTI series and you'll save a little money as well.
+1 on the rtis
Another vote for the RTiA1s - but keep your eye out for RTiA3s on Polk's ebay site - just a bit more, but worth considering!
i went and checked them out today and i dont think they'll look good with my setup...the vm's will match much better..i just have no way of hearing themTheater: Epson 8500ub, Elite 120" screen, Lsic, Lsi25, Lsifx, SVS Pc12plus, SVS Pc12plus, Emotiva Xpa-5, Denon Avr3311ci, Sony Bdps1000es
Weight Room: Panasonic TCP46G10, Polk Pswi225, PS3 -
Not many owners of the VM's seem to post here very much but for the most part they seem to get good comments from those that hear them. I think that most just feel the RTi's and LSi's offer a better price/performance value for their particular tastes. If you do some searches you might be able to find some photos of some wall mounted.
Different speakers but here are some pics of a similar sized wall mount speaker built into the walls (they are both around 4" deep) to show another option you can consider.
This is a nice clean install by a member here, the Mythos are about 9" taller than the VM 20's but it might help give you an idea.
http://www.polkaudio.com/forums/showpost.php?p=1136342&postcount=1 -
wow that is a very nice looking install. I wonder how deep the cabinets are and how exactly they're mounted. attached to the side of a stud?panasonic th-50pz85u
pioneer elite vsx-92txh
pioneer elite bdp-05fd
emotiva xpa-3
monster power hdp 2550
sa 8300 hd dvr
sda 2b's
fronts - rti a9's
center - csi a6
surrounds - fxi a6's
sub - polk dsw pro 600
harmony one -
i have the RTI A1 as my rear surround and they are great.
I just heard the VM 20's at a friends house. He had the VM10's for rears and I think a PSW sub. It sounded really, really good... but I think you def need to get a strong sub. I am thinking of getting the same set up with either DSW Pro 600 or MicroPro 3k.50" Sony LCD
Denon 3805
Polk Audio RM 20 system
Polk Audio 12" sub
PS3
Wii
Harmony One
HT system #2
55" Samsung LED
Pioneer Elite VSX 23
Fronts, Center- Polk VM 20
Rears- Polk VM10
Sub - DSW Pro 600
Harmony 900 -
Between the A1s* and A3s get the A3s! slightly more $, lots more performance! Either is a great choice**!
* for a very small room
** include a sub a sub if your serious about HT at any levelSamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
*soldered **Rob the Man (Xschop) LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & Mids - 981, connected w/Monoprice Premiere ICs
Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Opps! Regardless which series you pick get a center speaker from the same series. (e.g. RTi A=CSi A; LSi9=LSiC, etc)
I'm using a CSi A6 with A5s/1sSamsung 60" UN60ES6100 LED, Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga: LCR mids “Foamed & Plugged**”, inside* & out
Hi Eclimax
I would suggest going with the rti's, especially if it is primarily an HT setup. If space is an issue, I have my setup in a room that 14x12. I have taken some pics. Please excuse the mess with the wires. I have just hooked up my new Panisonic plasma and haven't had a chance to get things fixed up properley yet. As you can see this is a fairly small space. I can tell you that it sounds very nice."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
I have my speakers wall mounted: fronts, center and rears.
It works for my room layout: RTiA3s and CSi3 for fronts and RTi4s in the rear.
http://erikt.cts.com/Pictures/hometheater/home-theater-valor.JPG
http://erikt.cts.com/Pictures/hometheater/RTI4-Omni-mount-2.JPG
