B & W 801 too big for room?
Rennrig
Rennrig Posts: 16
edited December 2009 in 2 Channel Audio
Happy Holidays,
I have a system with a pair of B & W 801's placed six feet apart at the end of a 18-20' long X 10-12' wide room with 8' ceilings, glass down one wall and bookcases down the other. I am running a Krell KAV 250 amp with a conrad johnson "Classic" preamp with phono stage.
I am getting terrible separation between the bass and mid/tweeter. Either not enough or too much. I am wndering if these speakers are simply too large for the room. I have inverted the phase (as suggested by cj) and tested both configurations with mixed results depending on the recording.
Also....there is a large 60" doorway just adjacent to the left speaker, that I can't close. The bass seems to be possibly leaking out the door??
Any ideas?
Cheers,
Rennrig
Post edited by Rennrig on
  • zarrdoss
    zarrdoss Posts: 2,562
    Seems like you have all top notch stuff, could be the room. Are you using any room treatments? Tried moving your speakers further apart? maybe a diagram on your set-up might help.
  • Face
    Face Posts: 14,340
    It sounds like you may be sitting too close.
    Are they brand new, maybe you should give them some time to break in.
    Are they boomy at all?
  • zingo
    zingo Posts: 11,258
    As Face suggested, I would try moving them to 8' apart and see what happens. That seems to be the magic number with me and most of the speakers I try.
    Welcome to the Club Rennrig and post a picture or two of the great gear if you get a chance. :)
  • Rennrig
    Rennrig Posts: 16
    Sounds good, I will try and get the speakers further apart, and maybe further away from the rear wall. These 801's fire passively out the back which might be part of the problem. I have a pair of RTi A7's on a HT set up I can swap into this room also, to see if a smaller bass profile improves the situation.
    Merry Christmas,
    Rennrig
  • danz1906
    danz1906 Posts: 5,144
    Nice system, are the 801 Matrix or Nautilus series?
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Rennrig
    Rennrig Posts: 16
    Sorry, Typo, they are 802D Nautilus.
  • jax3822
    jax3822 Posts: 88
    Wow, nice stuff. I hope you fiigure it out. I am having a similar problem with my Ls70's in a much smaller room. The bass overpowers the stereo separation unless I spread them apart to about 8 feet. The problem is when I do that I am now blocking my doorway to my laundry area and my wife will not let that happen. When I throw the speaker out to the side like that, imaging improves dramatically. My room is only 17 x 15 with 7 foot ceilings. So yes, I believe it is possible to have speakers too big for a room. It is most true of a subwoofer to be to big for a space, in fact some makers market them by room size (HSU). I am considering adding an equalizer to reduce the bass output of my LS70's, or the possiblity of using port plugs.
    Good luck, and I hope you figure out your problem.
  • danz1906
    Rennrig wrote: »
    Wow,,,,,Very Very nice speakers:D
    If you cant get them to work in your room, I will keep them for you;)
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    Odyssey Mono-Blocs
