Monitor 10B XO upgrade, which schematic
jzheng
Planning the XO and RDO198-1 tweeter upgrade for my 1988 monitor 10B speakers.
No doubt the "schematic_m10_sl3000" will work.
But also found the "schamatic_m10s_rev2" schematic, which uses the same mw6503 drivers, and a SL2500 tweeter (Is this the same as SL3000?). The rev2 schematic caught my attention because it looks much simpler than the sl3000 schematic.
Question: Does it make sense to upgrade my existing 10B to rev2 and use the RDO198-1 tweeter?
-Joe
-Joe
Post edited by jzheng on
If you want to use the RD0-198, use the SL3000 schematic."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for your reply.
The question is: Is SL2500 the same as SL3000? If yes, the "Rev2" schematic would work with the RD0-198 too, right? -
No.."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
