subwoofer
edited December 2009 in Speakers
Budget= around 300.......
Found this Mirage BPS-150i for pretty cheap, was wondering if I should go for it or just get a dsw 600 off the ebay site. I am looking for something that will give me that loud as hell movie experience. Open to other suggestions for this price range too! I like USED and refurb stuff
HOME AUDIO:
Electronics:
HK 354
Front Power: CARVER TFM-35
Center Power: Audiosource Amp One
Speakers:
Center: CSi5
Fronts: rti10s
Rears: monitor 50s
psw 125 + psw 505 = BOOM
CAR AUDIO
Infinity 6032CF's all around
Post edited by royalty on
Welcome!
    How cheap is the Mirage? That's not a bad sub at all.
    its around 250
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    Im seeing it is probably pickup only so I may have to pass on that one....any suggestions. Is the dsw 600 very loud?
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    royalty wrote: »
    i have the DSW pro 600 in a 18X24 room with RTIA9s and it sounds excellent , goes deep without boomness, in rambo my seat shakes and it never misses a beat, looking forward to add an another one.
    audition it, it's great.
    Right now I have a psw125 and I am wondering if the dsw pro 600 would be a worthwhile upgrade. The psw just does not get as low and as loud as I want.
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    Any other suggestions for a used sub that is low and loud at this range
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    Velodyne SPL 1000 ?
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    Don't pass judgement on the DSW subwoofers based on your experience with PSW series subs. The new line is much better than the old and the Pro's are a worthy contender.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    royalty wrote: »
    i auditioned the PSW125 at the time and it sounded flat in the showroom where the RTIA9 were connected to AMPs, they sounded lower (they are rated 17HZ), the DSW pro 600 has a presence, as per Polk it's 8 times louder on the ultra low rating (90.5 db 32 HZ rating VS 100 db 20 HZ rating), the DSW is totally different than the PSW.
    How would you compare the 600s loudness to the 125
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    I know there some people out there with some great subwoofer suggestions!
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    royalty wrote: »
    How much do you want to spend...did you say how big your room was? I can't compare the 125 to the 600 but I can speak about its predecessor the PSW12 which on paper was only a 100 watts but hit a bit deeper....with a lot of port noise...the PSW could get pretty loud in a 25 X 11.5 X 8.5 room but it didn't get much below 33hz. I now own a sub very much like a 600 spec wise....a 12" of 300 watts RMS/600 peak with a 25hz low and I'm getting much more of that LFE LOW END from it. So yeah the 600 will play considerably louder and lower than the 125....in fact although the 125 is more 'controlled bass' than the PSW12---it does not go as LOW.
    Other subs to look at are SVS and HSU subs in your price range...you can find them on line...And Velodynes (12") 200 or more watts RMS--the numbers keep changing--go to their sites....Any of these subs will give you more of what you want.
    Personally I'd go with about a 550-600 dollar SVS 12"....plenty of slam for you! Another good bang for your buck seems to be Elemental Designs subs? Also online.
    cnh
    Im not entirely sure the exact size of my room but I think its no bigger than 15 x 15 its really not too big. My budget is around 300, which would mean maybe a little over at most. I am very open to used options. I am just asking is there some decent used sub for around my range that would fit what I want or will the refurb 600 do just that
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    royalty wrote: »
    In your room, the 600 will do more than fine.
    I run a MicroPro 1k (MUCH smaller and doesn't get near as loud as a 600) and it does a good job of filling in my 14x14 room with tight, accurate and punchy bass.
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    If you are looking for low and loud and not something amazing for music I really like my Klipsch Sub 12s. Even 1 of these in a mid size room is enough to shake the walls and I enjoyed it so much I bought another. A used one in good shape normally fetches between 250 and 300 after shipping on ebay. It is now discontinued so you can't find them new besides online. Vanns.com sells a new one for 350 with free shipping...
    royalty wrote: »
    where is thuffman? :p
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
    Well amigos here is what I did: I saw on Newegg they had a psw505 for around 200 with free 3 day shipping. So I purchased it and am going to keep my psw125 and use the subs together. I know together they will bring that loudness I desire and the psw505 will supposedly hit some of those lower hertz that I am desiring. Hopefully I will like this. If not I will definitely sell them both and spend somewhere in the 400 range for a good used sub. Comments....ideas....
    HOME AUDIO:
    Electronics:
    HK 354
    Speakers:
    Center: CSi5
    Fronts: rti10s
    Rears: monitor 50s
    CAR AUDIO
    royalty wrote: »
    a good choice,
    u have to adjust the subs in order to smoothen the bass effect across ur setup, try to consider getting a sub raiser which helps out in getting more dbs out of your sub.
    That'll work!!
    cnh
Welcome!
Welcome!
