please teach me to tag phrases
Tony M
Tony M Posts: 11,567
edited December 2009 in Forum Testing Area
I Taged a phrase once but just can't seem to be able to tag again. What am I not doing ????
Post edited by Tony M on
  • Knucklehead
    Knucklehead Posts: 3,602
    That feature is no longer available.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    I meant to say quoting I think.
    Aren't they the same?
  • concealer404
    concealer404 Posts: 7,440
    Knucklehead thought you were talking about "tagging a thread." That got taken away because of abuse.
    Quoting.... just click the "quote" button on a post. Then make sure that your reply is AFTER the [/QUOTE]
    I've tried quoting but nothing gets quoted .
    I'm going to try again now.
    nothing!
    ok..
    quote first to start a reply.
    I was starting a reply first. That's why I think it would'nt work.
    Now what's the trick to multiple quoting?:confused:
  • concealer404
    Start it just as you always would.
    Then on the "Topic Review" underneath the reply that you're currently typing, copy the post that you're wanting to quote in addition. Type
    membername wrote:
    then paste the copied post, and close your tag with the normal [/ quote]
    Type your reply. Wash, rinse, repeat as necessary. :)
    I'm going to have to practice that extra quoting in a little while.
    I'm going to try and order some cables from parts express now.;)
  • superjunior
    superjunior Posts: 1,632
    been trying to figure this one out as well, where does it say topic review?
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • concealer404
    When you reply to a topic NOT using "quick reply" scroll down. You'll be able to see the last 20 posts or whatever in condensed form underneath your reply field.
    Awesome! Like i said, for the money, you can't go wrong. From the weight of these things, it'd cost the same just to buy the bare copper. :p
  • superjunior
    awe hell, what did I just do?
    almost
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • concealer404
    almost
    You quoted my half of a quote tag with "membername" in there and it messed everything up. :p
  • superjunior
    sure did :p
    ok, I see the topic reveiw section at the bottom, but right clicking is not giving me the copy option :confused:
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • concealer404
    sure did :p
    You gotta highlight it first, then right click on the highlighted text. Or just use ctrl-c. Who uses their mouse these days, anyways? :p
    Another way to explain the multi-quote:
    Hit the quote button on a post you want to quote.
    Then the next part you want to quote, just make sure it matches what was automatically pulled by the quote button, but change the name and text content as necessary. Leave everything else inside the brackets alone.
  • superjunior
    you da man!
    Today 11:20 AM
    almost got it! thank you sir!
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    almost got it
    me, I'm an old **** :p
    thanks concealer
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • bobman1235
    bobman1235 Posts: 10,822
    If you don't like all that copying and pasting and typing of the [ quote] tags, there's a multiquote button. In every post, you see a ">quote" button, then a smaller button that looks like two squares on top of each other, and then a return arrow. The middle button (the squares) is multi-quote. Click that box on each post you want to quote, and on the last one just click the regular "quote" button, and you'll have multiple quotes.
    Confusing the way I explained it but if you play around you'll figure it out.
    Me too:(
  • hearingimpared
    hearingimpared Posts: 21,136
    bobman1235 wrote: »
    Bingo!!!
  • concealer404
    bobman1235 wrote: »
    Oh holy crap. I never even noticed that.
  • superjunior
    Bingo!!!
    bobman1235 wrote: »
    wow, thats much better!
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • superjunior
    ok, got multi quoting figured out. how about just quoting a portion of a post?
    say you only want to quote a sentence from a post
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • tcrossma
    tcrossma Posts: 1,301
    Just click the Quote button on the post you want to quote, and delete the portion(s) of text that you don't want.
    Speakers: Polk LSi15
    Amp: Pass Labs X-150
    CD/DVD Player: Classe CDP-10
    TT:Micro Seiki DD-35
    Cartridge:Denon DL-160
    Phono Pre:PS Audio GCPH
  • hearingimpared
    You could hit the quote button and delete all of the unwanted text between the quote codes or you can highlight and copy the sentence(s) paste them into the body of the reply area and click the quote button. It is the fourth button from the right on the lower set of buttons at the top of the message box.
  • superjunior
    You could hit the quote button and delete all of the unwanted text between the quote codes .
    thanks guys
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
  • mjulrich
    mjulrich Posts: 1
    bobman1235 wrote: »
    Everyone, Thank you. I was trying to figure the quote function out and stumbled on your thread. This has been very helpful if my message posts correctly. :eek:
    cool
    mjulrich wrote: »
    :)[/QUOTE]
