Polk Momo Active System Help
Col_S
Col_S Posts: 16
edited April 2003 in Car Audio & Electronics
I am running 2 x MM120s, 2 x MM465 mids and 2 x MM465 tweeters active in a small hatchback, subs in the boot and components in the doors. I will be using time alignment and a 10 band parametric eq. I can have up to 75wrms to each mid and tweeter and 400wrms each to the subs.
My crossover can do:
The Subs lowpass at 78 or 99 with a 36 or 78 dB/oct slope
The Mids high pass at 78, 99, 500, 793 or 1.25k with a 24, 36 or 78 dB/oct slope
The Mids low pass at 500, 793, 1.35k, 4.00k, 5.03k or 6,34k with a 24 or 78 dB/oct slope
The Tweeters high pass at 4.00k, 5.03k or 6.34k with a 24 or 78 dB/oct slope
What should i set the crossover points at, (what slope and frequency) and what power should i give to the mids and tweeters (MAX of 75wrms). I want the best SQ possible. The music i listen to is Eminem, Dre, 50, Royce, N.E.R.D., Snoop etc!!!
Post edited by Col_S on
  • Col_S
    Col_S Posts: 16
    edited April 2003
    I didn't post all the information at first but it has now been updated.
    Please help!!!
    Colin
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    edited April 2003
    this is way outa my league.... but.... i dunno my personal pref's regarding slopes and x's usually fall as follows...
    low pass subs at 78 w/ 24
    mids high pass at 78 w/ 78 db slope --- i'm happy w/ my 100 hz / 12db -- but that is also because i've got a rear fill covering the 70 - 100 range... lacking the fill, i would assume u'd have to drop your fronts down to where your subs break off. the sharper slope should make it work well. put a brick wall between them and harmful bass and life is good.
    can't tell u where to HP the mids at -- never had to deal w/ it.
    high pass tweet at 4 k -- i prefer 12 db/octave but the lowest u've got is 24... i realize the precision of a sharper slope but i also like the smoothness of a lesser sometimes.
    The Artist formerly known as PoweredByDodge
