FS: POLK PA 500.4 & 1200.1 amps - BNIB
Thunderplains
FOR SALE:
Brand new, never used.
Polk PA500.4 Amp
Polk PA1200.1 Amp
I am shedding half my amp install as I am changing my setup a little.
You pay what I paid, not looking to make $$..
SPECS:
500.4 -
* 125 watts x 4 continuous, 200 x 4 dynamic power (2 ohm load), 4 channel mode.
* 250 watts x 2 (4 ohm) continuous power, 2 channel mode.
* CEA-2006 Compliant specifications for true, accurate power ratings.
* 4-channel, dual bridge-mono (2-channel), or dual simultaneous stereo/mono operation provide a variety of configurations and setups: 4-channel for front and rear speakers; 2 speakers and a sub; 2 subwoofers; or 2 subs and 4-channels in passive-tri mode.
* 2 ohm stable 4-channel operation.
* High-speed MOSFET switching power supply and high current Bipolar Output Transistors pump maximum voltage and high current to your speakers or subwoofers.
* Double Layer Fiberglass Epoxy Printed Circuit Boards for more rigidity, less shrinkage and a smaller overall amp footprint.
* 6-Way Smart System Protection (SSP) circuits
* Fully adjustable (50- 500Hz) 12 dB/octave high- or low-pass crossover. Defeatable for full range (flat) operation.
* Switchable 8 dB bass boost at 40Hz for extra bass thump.
* Variable input gain optimizes match with different signal sources (250mv to 7.5V).
* RCA Outputs (front channels only) for easy daisy chaining of other amplifiers.
* Mounting hardware with rubber isolation grommets and extra fuses included.
* Light Bar/Fan Output- Connect an optional LED light bar or cooling fan for custom installations.
* Multi-Color Status LED gives instant information on amplifier operation.
* Remote Subwoofer Level Adjuster for rear channels included.
1200.1 -
* Monoblock amplifier for subwoofer use and particularly ideal for the SR Series.
* 1200 watts x 1 (1 ohm), 800 watts x 1 (2 ohm) and 400 watts x 1 (4 ohm) continuous power. CEA-2006 Compliant specifications for true, accurate power ratings.
* 2400 watts x 1 (1 ohm) dynamic power.
* 1 ohm stable design can drive even the most demanding subwoofers.
* Super Efficient Class D Pulse Width Modulation amplifier design. Draws less power and runs cooler so you won't heat up the inside of your vehicle or make the headlights dim.
* Anodized extruded brushed-aluminum cover for maximum heat dissipation and great looks!
* Cast aluminum textured end caps for optimized heat dissipation and hiding of connectors. Solid aluminum logo and model panel back lit in cobalt blue.
* Adjustable 12 dB/octave low-pass crossover (30-250 Hz).
* Switchable 24 dB/octave subsonic filter protects ported subwoofers.
* Switchable 180° phase inversion for easy sub to main integration or external bridge mono operation.
* Remote Subwoofer Level Adjuster included.
* Master/Slave switch and RCA Outputs for easy daisy chaining of other amplifiers.
* Master/Slave switch allows parallel operation- master amp's gain and crossover settings will be duplicated in "slave" amplifiers for consistent, repeatable settings.
* Power and ground terminals accept bare wire up to 4 AWG. Terminals use standard #2 Phillips head screwdriver- no more hex wrenches to lose or strip!
$575 shipped for both
If you want to pay by paypal, add 3%.. Thx
Polk PA500.4 Amp
Polk PA1200.1 Amp
SPECS:
500.4 -
1200.1 -
Post edited by Thunderplains on
how much for the pa 1200.1 shipped.........to India?
Wish I could.. Cost would kill me.. Know anyone state side??
Anyways, to any watchers.. I will ship fedex overnight at no additional cost. -
DAMN!!!! That is a hell of a deal....somebody better jump on that quick before he changes his mind.
TTT - FedEx Overnight, no charge
JoshParsons84 wrote: »DAMN!!!! That is a hell of a deal....somebody better jump on that quick before he changes his mind.
Looking at Crutchfield its a savings of $34.98Denon 3806 Receiver
Denon 3910 DVD
Oppo BDP-83 Blu-Ray
Outlaw 7500 300w x 5 @4 Ohms Amp
58" Panasonic 800U 1080P Plasma TV
SVS PB-12 Plus Sub
Lsi25 Fronts-Cherry
LsiC Center
LsiFX Surrounds
SMS-1 Velo Sub EQ
PBJ Interconnects
Blue Jeans Cables
Everything was going just fine till my buddy poked the cop in the chest and said "did Andy give you your bullet today Barney?" -
Sure, but add the fedex charges.. you are looking at well over $125..
And Crutchfield has had the 500.4 out of stock for awhile.. I have it in my hands..
Ok, dropping to $550 shipped FedEx overnight.. Xmas anyone?
Morning bump.. $550 shipped FedEx overnight.. Good deal..
Post Xmas bump.. $540 final with Overnight..
Still got it? I'm interested
Still got it.. lmk, as I am waiting on a buyer to get back to me later..
I'm down. Just let me know what's up and I'll nab them from you. Thanks!! I'd just send you a pm but I need to post more on threads first I guess
Sold to Zxylon.
