PSW110 - Not Impressed Yet - Are my Settings Off?
seadoons
I finally received my system and set it up yesterday. I am going to be primarily listening to music. So far, the sub hasn't impressed me.
This is my system:
Receiver: Onkyo TX-SR607
Fronts: Polk RTi4
Center: Polk CSi3
Rears: Polk RC85i (not installed yet)
Sub: Polk PSW110
I have the sub volume knob all the way up. Shouldn't it be rattling the walls? I think something is not right.
1. I am using a standard RCA cable. I have a "sub" cable on order - will this make a difference?
2. Is there some setting on my receiver that I am missing? I feel like I have gone through all the settings but maybe I am missing something.
Any suggestions you can offer are appreciated. I just thought that this 10" sub would rattle the walls but it isn't doing that. The manual says to start at 50% volume when making adjustments and at that volume I couldn't even tell if it was on or not! Help!
This is my system:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Rears: Polk RC85i (in-ceiling)
Sub: Polk PSW110
Patio: Polk Atrium 45
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Post edited by seadoons on
Considering you just purchased it, I'd say let it break in properly before cranking it the hell up.
Another thing is, you're only half way done now that you've purchased a subwoofer. Placement is extremely critical so please play around with placement before passing off any judgement on any subwoofer. You'd be surprised to find out how well it plays once you've found a proper spot to put it in.
You also have to dial it in correctly in terms of volume, crossover, and phase settings. Do all that correctly and you'll have a sub that blends in perfectly with your speakers but gives you the 'oomph' you're looking for.
-FreddyTruck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I believe your reciever has a feature called "Double Bass" or something like that.
I had to use it to get any noticeable activity on my old Omni S8s when i was using an Onkyo TX-SR503.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Thanks for your responses. I am 100% not passing judgement on this thing yet as I know there is a setting off somewhere.
Right after I started this thread I figured out that the receiver had adjusted the sub volume way down. I guess with the auto-calibration it can control the volume of each individual speaker and it had turned all of them way down based on the listening positions I had established. No wonder I had to turn the receiver up to 50 to get volume out of it. I have it at 30 now and the volume is perfect!
So - long story short, I found an adjustment for the sub volume (you can take it down -15DB or up to 15DB) and I turned it up to around 9 or so (it was at -1).
You can definitely hear it now...I don't want it to literally shake the walls but I want know it is there.On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Accessories: Onkyo UP-HTI HD Radio Receiver, SIRIUS SUPH1 Home Kit, Onkyo UP-A1 I-Pod Dock -
Regarding placement - I am really confined to one space with it. It is inside my entertainment center cabinet (it is enclosed). I do seem to notice the bass more in other rooms that I do in the den where it is but it still sounds good in there too.On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Regarding placement - I am really confined to one space with it. It is inside my entertainment center cabinet (it is enclosed). I do seem to notice the bass more in other rooms that I do in the den where it is but it still sounds good in there too.DARE TO SOAR:
Your attitude, almost always determine your altitude in life -
concealer404 wrote: »I believe your reciever has a feature called "Double Bass" or something like that.
I wouldn't use this feature as it really taxes the receiver. At least on mine, when driving 4-ohm DefTech towers because it ignores the crossover and essentially sends the bass to the front speakers LF + sub.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
You might also consider rising the subwoofer (you can get manufactured sub risers are embark on a slick DIY) and that can improve your bass response considerably. For a standard 8ft high room, lifting the sub 15-24inches is ideal.
And I totally agree with Techno - don't enclose the sub. Good luck on getting it completely calibrated and setup!Living room:
Optoma HD20
Elite Sable 100"
Marantz NR1501
Polk RM6750
Polk Monitor 50 x 2
Polk CS1
2 x Polk PSW110
2x Sennheiser RS120
Toshiba HD-A20 x 2
Vizio VBR220
Sony CDP-CE375
Xbox 360 Elite
Bedroom:
Olevia 242T
Sony BDP-S370
Xbox 360 Pro -
Serendipity wrote: »I wouldn't use this feature as it really taxes the receiver. At least on mine, when driving 4-ohm DefTech towers because it ignores the crossover and essentially sends the bass to the front speakers LF + sub.
Hrmmm... i didn't notice that on mine... Are you sure it's sending it out to the mains?
Even when just running test tones, it made no difference in the mains on mine, it just did exactly as advertised, increased the LFE signal...I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
I just got an onkyo reciever and some polk surrounds and sub to go with my S10 front towers. I found the audessy eq thing in onkyo to be well not so good. I've been tweaking the settings myself and getting a much nicer more round sound out of it. I did as recommended on here and set the crossover on the back of the sub all the way up and the volume on the back of it to 12:00 position. Still adjusting settings in the reciever and getting everything broken in.
op, what size room are you trying to fill with that sub?Samsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
The room is 18 x 20. I am much happier with it now that I have made several adjustments. The receiver had adjusted the sub volume down so I bumped that up and then also adjusted the crossover point for the fronts to 40 so they aren't pushing as much bass (although they sounded surprisingly good on their own).
I plan on installing the two in-ceiling rear speakers next week and will continue to make tweaks to it but right now I am happy...even with it inside the entertainment center!On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
THERE IS YOUR PROBLEM :rolleyes:HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Ah yes, I have heard this a few times now. I don't really have much choice as this was the deal that I worked out with my other half before buying it all. My 25 foot sub cable arrives today...I am going to try putting the sub in other places in the room to see how much of a difference it really makes. It if is a HUGE difference I will work on keeping it there...On a UPS truck on the way to my house as of 12/09/09:
Fronts: Polk RTi4
Center: Polk CSi3
Sub: Polk PSW110
Trust me it will be a huge difference.HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900 -
bigaudiofanatic wrote: »THERE IS YOUR PROBLEM :rolleyes:
Big time (must be boomy as hell)!!!DARE TO SOAR:
And probably chocking itself in there. LET IT BREATHE MAN!HT setup
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
Samsung BD-C7900
