Velodyne OPTIMUN - 12" subwoofer
Bernal
Velodyne OPTIMUN - 12" subwoofer...any feedback on this sub......thanks
http://www.velodyne.com/products/specs/OptimumSpecs.html
http://www.velodyne.com/products/product.aspx?ID=37&sid=569y987w
Post edited by Bernal on
http://www.hometheaterhifi.com/subwoofers-products-menu-column1-41/516-a-secrets-subwoofer-review.html?showall=1
Written by Jim Clements
Sunday, 21 December 2009 17:00
ARTICLE INDEXVelodyne Optimum-12 Subwoofer
Page 2: Design and Set-up of the Velodyne Optimum-12 Subwoofer
Page 3: The Velodyne Optimum-12 Subwoofer in Use
Page 4: Conclusions about the Velodyne Optimum-12 SubwooferPage 4 of 4
Conclusions
In general, my theater space comprises three parts. The main part is roughly 25 x 25 Almost a perfect square. The other two parts are two contiguous rooms that are connected to the main space by way of large openings. The acoustics of the space are generally very good, but the room does incorporate a large volume of air, presenting a potential source of strain on a subwoofer. To be honest, I was concerned that the Optimum-12 would have difficulty achieving reference levels in this space. Now that I have been able to spend some quality time with this sub, I am pleased to report that it handled just about everything I threw at it without obvious signs of strain. As long as the sub level was set to properly integrate with the rest of the program material, the sub went about its business without complaint unless I was attempting to play rock music at insane live concert levels. Not that Ive ever been known to attempt a stunt like that!
The street price for the Optimum-12 will probably be around $1,500. At this price point, I would say it is a good value and worthy of consideration if you have a subwoofer budget of up to $2,500. I, for one, could happily live with an Optimum-12, even in my large theater. -
...Velodyne OPTIMUN - 12" subwoofer...any feedback on this sub......thanks -
Don't know this sub...but I have heard any number of Velodyne subs and I would say that this is probably a winner. V subs get better as you move up the chain...at this price point it's probably a good bet that a lot of R&D was spent on its design.
Usually Velos have a very controlled bass and know how to handle the roll off frequencies so that they don't distort or bottom out.
Why do you ask, Bernal? Are you considering this model?
cnh
Thanks for your reply.
Yes, I'll buy it and installing it on Sunday.
Thank you. -
no love for the micropro 4000? it's in that price range and goes lower.
Hello
I received my Optimum.
I am happy with purchase:):):):)
