Should I leave my center a small or large??
Kenshin81
Kenshin81 Posts: 18
edited July 2011 in Speakers
I have a RM series 2 center and I was wondering should I leave the option as small or large??
Post edited by Kenshin81 on
  • ken brydson
    ken brydson Posts: 9,005
    edited December 2009
    Kenshin81 wrote: »
    Small. I run a big **** CS 350LS as small...
  • kcoc321
    kcoc321 Posts: 1,788
    "small" or "large" is misleading.
    Think more "crossed over" = small and "un-crossed over" = large
    Depending on your receiver, you can also change the crossover point.
  • danz1906
    danz1906 Posts: 5,144
    Small.........crossover at 80hz should work.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • anhchungdoan
    anhchungdoan Posts: 760
    Kenshin81 wrote: »
    As previously stated by some posters, try small setting @ 80 hz all 7 speakers and let your good sub do its job.
  • hearingimpared
    hearingimpared Posts: 21,136
    Same here.
  • mystik610
    mystik610 Posts: 699
    Use your ears to decide.
    Most people recommend using an 80hz crossover point for the fronts and reas (ie running them 'small'), and using an 80hz LPF for the sub. Speaking very generally, this will allow more power to be delivered to the upper frequencies of your speakers and improve their dynamic range, while the sub will adaquately handle anything below the crossover point. I ran my set-up like this for awhile, always feeling like there was a disconnect between my sub and the speakers. One day I decided to go against the norm, and set my fronts to 'large', and I never looked back. Now the fronts sound fuller, and more importantly they integrate much better with the sub.
    It should be noted that I have a fairly large living-room and my sub is located nearfield, making it more easily localizable. The point is, every situation is different, and you should follow what your ears tell you rather than relying on the general consensus. Crossing over your center at 80hz is a good rule of thumb, but try other alternative as well.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • superjunior
    superjunior Posts: 1,632
    mystik610 wrote: »
    +1, those large mids aren't there to just look pretty.
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • jax3822
    jax3822 Posts: 88
    I vote for small. Check the freq. response for the center, most dont hit down that low to warrant receiveng a full range signal. Plus most of the signal processed through the center will be above 75hz anyway.
  • thuffman03
    thuffman03 Posts: 1,325
    Small unless you are running a Definitive Technology CLR 3500 which has a built in powered sub.:cool:
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • anhchungdoan
    Try either way and stick with the set up YOU like the most. I prefer all small @ 80 hz but it is your ears that will tell you which setting is best for them.
  • 20hz
    20hz Posts: 636
    edited June 2011
    ditto .
    Any speaker you set to large will suck bass from the mains (thats bad) and since there is not real bass in a center (dialogue) channel I prefer all bass in the mains .
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    Small.
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    Small especially the RM series. I have them crossed over at 80hz and set to small. The sub supplements the needed low end just fine.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited July 2011
    The RM series speakers are designed to operate at above 95hz, so this speaker has NO business playing lower frequencies, which you would force on it if you set it to "large".
    Small all the way, no doubt.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
    tonyb Posts: 33,072
    edited July 2011
    Lietuvis91 wrote: »
    Bingo....agreed. Forcing a speaker,any speaker to go beyond it's capabilities will not end well.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited July 2011
    Ha ha! The OP hasn't posted in a year and a half. I wonder if I bump it back up, if anyone else will answer his question? :wink::biggrin:
  • kevhed72
    kevhed72 Posts: 5,146
    edited July 2011
    Small....and try to get the speaker as close to ear level as you can - huge difference.
