using 4 ohms LSI F/X surrounds with 8 ohms receiver
newpolkuser
newpolkuser Posts: 3
Hi - I am a novice and have a question. I recently bought LSI F/X surrounds for my home theatre set up. I made the mistake of not checking the impedence of these speakers before purchasing. Now I realize that these are rated at 4 Ohms where as my receiver (Denon AVR 3803) is rated at 8 ohms. Before I hook them up I wanted to get some opinions from other users out there if it really matters. Specially, considering that these are surrounds, does it make a huge difference? I got them at a good price so would not want to return them, but if the difference between the receiver and surround speakers resistance REALLY matters so much that it will either blow up my receiver or the speakers, then I don't want to keep them. Thoughts/comments? Thanks.
(Not sure if it matters, but if it does, my front speakers are RTi A9s and the sub woofer is micro dsw 4000.)
  • danz1906
    danz1906 Posts: 5,144
    edited December 2009
    Welcome to the Club!
    You may be ok since those are your surround speakers.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • newpolkuser
    Thanks for your responses. I have not bought a centre speaker as yet. Thinking of a CSi A4 or A6. Also, point noted regarding the pre-amp but can't afford it as of now. Like I said, I am a novice, so till the time I actually hear the RTis with a power amp, I wouldn't know any better. To my untrained ear they sound good even with just the Denon 3803.
    Going back to my original question regarding the difference between the impedance of LSi (4 ohms) and the receiver(8 ohms), since these are just surrounds I am thinking I may be ok. Polk audio tech support also says that it should not matter that much. Wanted to validate my thought process with the experienced folks on the fourm. Thanks.
  • ben62670
    ben62670 Posts: 15,969
    Don't get an LSI speaker for the rears if you are using RTi's up front. They won't match properly.
    Welcome to Club Polk
    Ben
    Ben
  • sTiLlLeArNiNg
    sTiLlLeArNiNg Posts: 805
    Welcome to CP :)
    Even though i think the Denon could run a 4Ohm speaker i don't think it would be wise to mix impedence's :o
    ben62670 wrote: »
    Ben
    +1 I would return the LSI's and use the money toward's the correct "timbre" matched speaker's :cool:
    xcapri79 wrote: »
    If you have RTiA9's then the matching center is the CSiA6.
    An external amp will make your system sound better and you don't need to have a trained ear to hear the improvement.
    If budget was a concern, you should not have purchased the LSiFX's and stuck with choosing either the FXiA4 or A6 surrounds.
    Once you get into the RTiA9's or the LSiFX speakers you have moved up the food-chain. This is where you should consider using an external amp to get the sound out of your speakers that they're capable of.
    A capable external amp will cost less than the RTiA9's and is well worth the investment.
    Definately get the CSi A6/FXi A6 to match with the a9's ;) The a9's LOVE the juice and only get beeter as the power goes up! :D Going from AVR power to separate power is like night/day :D There are good product's available to get you into separate's without breaking the bank ;)
    Media Room 7.1
    Sharp lc37d64u | Sanus vmsab-03 | Sonax ZX8680 | Yamaha htr-6290b | Emotiva xpa1 x 2 & xpa5 | RTiA 9 & 7 | CSiA 6 | FXiA 6 | Sanus NF30B-03 | Velodyne dls-3750r | Dual 505-3 m97xe | Monster avs2000/hts5100
    HTPC
    Intel e5300 | Asus p5q DLX | LG ch08 BD | OCZ 4g reaper2 | WD 1TB | Sapphire 4890 VaporX 1g | Asus Xonar HDAV 1.3 | OCZ modXtreme 700w | Antec Fusion remote MAX
    A fool and his money are easily parted
    I don't drink Koolaid
    Need some cable's? Just ask :)
  • newpolkuser
    edited January 2010
    Thank you for all your responses.
  • BlueFox
    BlueFox Posts: 15,250
    edited January 2010
    I ran 2 LSi15s, 2 LSi7s, and an LSiC off a Denon 3805 for a year without any issues. I suspect you are okay for surround speakers since most energy is either in the center, fronts, or sub.
  • gp4jesus
    gp4jesus Posts: 2,025
    edited January 2010
    Welcome to CP :)
    i concur w/sTiLlLeArNiNg on the "timbre" topic. The layperson's explanation is lengthy and detailed that can be summed up in one word: phase.
    Also concur w/xcapri79 "If you have RTiA9's then the matching enter is the CSiA6." I (Tony) would NOT mix lines of Polk speakers. Again: phase. I've seen other mix different brands for LCR... ARGH!!
    If you get a separate amp for the LR or LCR you can likely get away w/ using your Denon's* amp to drive surrounds regardless of impedence.
    * I'm assuming the Denon of today is the Denon of old ('80s & '90s)
    cheers & have fun! tony
    *all connected w/Premiere ICs
  • dvran
    dvran Posts: 280
    edited January 2010
    Splice 4ohm resistors into your speaker wires. I've never tried but it would match the resistance then to the receiver.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • Eric W
    Eric W Posts: 556
    edited January 2010
    dvran wrote: »
    Nooooooo!!!
    -Eric
    -Polk Audio
    edited January 2010
    How about we make it simple for the dude, No, bring them back. See..simple.
  • bluecomet
    bluecomet Posts: 1,118
    edited January 2010
    You are going to blow those Lsi F/X speakers if you underpower them with a 8 ohm receiver at higher volume. Either buy an amp for the Lsi's or take them back. I have a 7.1 HT system of Lsi speakers and use F/X speakers for the surround and rear mains. They are great speakers. I went the external amp way to power my system even though my Yamaha can do 6 ohm speakers. I would hate to see you blow your speakers and be out the money you paid for them. Just some advice from someone who has been there. They will sound much better with an external amp.
    Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
    Yamaha RX-V2500 System, Carver A753 3 channel amp.
    Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
    Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9
