FS: Channel Island Audio VDA-1 & VAC-1 pics avail
byteme
byteme Posts: 73
edited April 2003 in Flea Market
Channel Island Audio DAC and upgrade power supply. Used over the last couple months and need to sell. Excellent sound that in my system beat out Rega Planet, McCormack Digital Drive DAC-1, EAD DSP 7000 MkIII. Dusty really put this little baby together! Reduced to $370 Paypal is preferred, split fees, shipping will be USPS priority mail and is included! Email or PM me for pics.
The VDA-1 is the perfect upgrade for any CD or DVD based system with a digital audio output. Careful design layout and short signal paths are used for optimum performance and flexibility. Inputs are via Toslink optical or RCA coaxial. The signal is then fed into a Burr Brown DIR1701 low jitter input receiver, then to a Burr Brown PCM1716 digital to analog converter. The analog output is routed through a Class A output stage utilizing a Burr Brown OPA2134 opamp. All signal path resistors are Vishay metal film types with polystyrene filter capacitors.
Inputs: (2) Toslink Optical, Coaxial SP/DIF
Locking Frequencies: 44.1k, 48k, 88.2k, 96k
Frequency Response: 20Hz-20kHz +/- 0.1db
THD: <.006% 20Hz-20kHz
Output Level: 2.4vRMS
Dimensions: 4.40"w x 2.65"h x 4.40"d
Our new VAC-1 is the perfect upgrade for our VDA-1 DAC or VPP-1 Phono Preamplifier. The upgrade yields improved bass definition, dynamics and noise performance. Features include internal 115-230v selector switch and IEC type AC socket for use with aftermarket power cords.
AC Input Voltage: 115/230VAC
Output Voltage: 14VAC @ 1.44 Amps
Accessories: IEC Type AC Cable, AC output Cable
Post edited by byteme on
