Internal Hock-up wire
ANWKLO
I have some un-used speaker wires around. Don't know it is suitable for the replacement of stock internal wires of Monitor 5.
It is marked " Denko Professional speaker cable > High Purity Copper> 2x120/0.12mm > Tinned + Untinned > Perfect Link for Audio"
What is the awg value?
Post edited by ANWKLO on
Looks like the stuff is going to turn green soon! Upgrading the internal wiring would never hurt, but I don't know if you want to use that stuff. At least cut the ends, strip off some new ends and solder the ends to whatever plugs are on the factory speakers. Kind of alot of work but maybe someone will correct me and say it's definitely worth the effort.
Btw, when I mean "plugs" I mean those little adapters on the end of the internal wiring that connects to your drivers.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
I believe 2.0mm=12ga.
If you use that wire, I would heat shrink the end. As Freddy mentioned, that kind of wire is susceptible to oxidation."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Which wire should be connected to the positive? Is the untinned wire (copper colour)? The hole at PCB seems not big enough for the wire to pass through. Do I need to enlarge it or just solder on top of the PCB? Thanks:)
Get some better wire or leave it stock.
Ben -
Ben
What do you think the Belden 8471?
http://www.twacomm.com/catalog/model_8471.htm -
Tinned and PVC insulation are bad. Look for some Audio Quest 14/2 in wall rated wire.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Check out cardas if you're going to redo the internal wiring.
-FreddyTruck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
15.5 is fine. I hope you have a soldering pot or a really hot iron, Cardas can be difficult to work with."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
15.5 AWG for both tweeters and drivers
I only have 30W and 60W hot iron. Which one is suitable? -
The Auri only provides 18 and 21 AWG hock-up wires. Are they good enough for the tweeters and drivers respectively
http://www.audience-av.com/parts/auricwire.php -
Your 60w may not be hot enough for Cardas, the 18ga Auri should work fine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
