Sda 2 help?
MileHigh10B
MileHigh10B Posts: 3
edited December 2009 in Vintage Speakers
I went to listen to the SDA 2's. The outer vertical row of one, 6.5" mid and one, one inch tweeter were not working. I looked in the back and the IC cable had disconnected itself. I plugged it in and they still did not work with all the other speakers working fine. It is the same on both speakers. The outer row not firing. The IC cable looks bent pretty good like the speaker was shoved hard against the back wall and put a crimp in it. So any of you know why the outer row of speakers on both would not be firing? These are the speakers in Denver on another listing here. Thanks Rick
  • stubby
    stubby Posts: 723
    If your cable looks bent, chances are good you have a bad connection. If you have a test light, check for continuity at the connector ends. I believe you need to check the small blade on one side, large blade on the other end of the cable. Hope this makes sense!
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
