Adcom GFA-5400, Thermal Problem
MLcubed
MLcubed Posts: 1
edited December 2009 in Electronics
Hello,
I would like some help in fixing a thermal problem with a Adcom GFA-5400.
Does anyone know a part number or Digikey # for the thermal switch between heatsink and PCB?
Any advice on ordering from Adcom?
Any advice on repairing this? It looks like a complete disassembly.
I have ordered the service manual off www.stereomanuals.com
Does this have part #'s?
The left channel will not play. The left thermal protection LED is on. The Thermal switch is open.
Adcom GFA 5400
copyright 1995 from PCB X-1232A03T
Serial: A541FB 05295
Thanks, Blair Sutton
Post edited by MLcubed on
  • fbm211
    fbm211 Posts: 1,488
    You can always contact adcom and they may be able to tell you what digikey part number you need.Maybe ben will chime in and help.He may be able to suggest what you should do as he has repaired adcoms.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
    heiney9 Posts: 25,432
    Try posting at
    www.diyaudio.com
    lots of guys over there can help you.
