psw 505
vprseries
Ibought this sub about a month ago and it works well. I do not have lfe working b/c my reciever isnt that great. The sub itself works fine but when i listen to my metal music i cant seam to hear the double bass very well. Idk maybe im just going deaf b/c this sub rattles my 2 story house.
any thoughts?
any thoughts?
Post edited by vprseries on
Your going deaf.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Welcome to the forum!
You might want to have your hearing checked if you can feel the rumble but can't hear it.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
Check the crossover on your sub, you may need to turn it a little higher to hear the bass drums. Try moving your sub around in the room too, its amazing how the placement and the XO can affect the sound.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
thanks guys i moved the sub in the opposite corner and that seemed to help some but it is prob b/c im going deaf
The 505 might not be quick enough to catch blast beats, as well, just causing a continues rumble rather than percussive pitches.I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
