HDMI TO DVI...no picture
trubluluc
trubluluc Posts: 2,067
edited December 2009 in Electronics
Guys-
I have a Mitsubishi rear projection TV (WS-55813) It has a DVI imput that says it will output 1080i. I recently bought a Oppo BDP-83 dvd player, which has a HDMI output.
I bought a hdmi to dvi cable and hooked it up, choose the same imput/output on the tv and the dvd player, but no picture. I hook up component and I get the picture, but at 480p.
Help me Mr. Wizard!
-Luc
Post edited by trubluluc on
  • steveinaz
    steveinaz Posts: 19,545
    Do you have the Oppo set to output 1080p? You may have to change it to 1080i. Also try 720p to see if it will work...
  • vc69
    vc69 Posts: 2,500
    steveinaz wrote: »
    Bingo!
    You may have to hook via component or composite to get to the setup menu.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    Muscial Fidelity M1 DAC
    VTL 2.5
    McIntosh 2205 (refurbed)
    B&W 801's
    Transparent IC's
    How OLD is your DVI...if it does not comply with HDCP standards that HDMI-DVI cable won't work period. Certainly try the suggestions above...but if they don't work it's a handshake problem due to HDCP--High Bandwidth Digital Content Protection!
    A wonderful acronym that's caused thousands of headaches so we can PROTECT Hollywood!
    cnh
  • pearsall001
    pearsall001 Posts: 5,297
    cnh wrote: »
    cnh
    You hit the nail right on the head. I have the same exact setup as the OP...my Oppo BDP-83 going straight to my older Sony LCD via an HDMI/DVI combo cable. It's not as issue with the Sony.
    This is right out of the Oppo manual (pg 11): HDCP stands for High-bandwidth Digital Content Protection. The HDMI output of the OPPO Blu-ray Disc player uses HDCP to encrypt the digital audio and video content. The TV needs to support HDCP so it can decrypt the content and properly display it.
    Check your TV manual to see if it meets this standard...if it doesn't, I'm afraid you're goung to have to use componet.
  • george daniel
    george daniel Posts: 12,096
    You just solved an issue that has had me puzzled for months--Thanks.
  • vc69
    vc69 Posts: 2,500
    Yeah, good catch cnh. I hadn't considered the age/compliance of his set.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • trubluluc
    Yes, I did set it to 1080i, still no picture, I will try 720p, but my tv doesn't list that as an option.
    thanks,
    -Luc
    steveinaz wrote: »
  • trubluluc
    Hmmm..... you may be on to something here, I'm sure it's an older version of DVI due to the age of the set. I will try what the others recommended and report back.
    thanks!
    -Luc
    cnh wrote: »
    cnh
  • pearsall001
    Reread post #5 & page 11 of the Oppo manual. You're beating your head up against a wall. You need to find out if your TV can support HDCP. If not you're out of luck. The issue is not with the combo cable or the Oppo...it's your TV's capability. And it has nothing to do with either 1080i, 1080p.
  • vc69
    vc69 Posts: 2,500
    If it has component inputs then of course, that is the solution. Maximum resolution of 1080i of course. Good luck and let us know how it works out.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • trubluluc
    There is no mention of HDCP anywhere in the TV manual.
    So I guess I upgraded to a "better" dvd player with no real advantage over my current Onkyo SP-1000. :(
    Thanks for clearing this up for me guys!
    I wish the people at Oppo had been more upfront about this possibility.
    I drove over to their facility to pick up my DVD player with my TV manual in hand,
    and asked them point blank if this would work.
    I was told as long as I had a DVI, "no problem".
    -Luc
  • vc69
    vc69 Posts: 2,500
    trubluluc wrote: »
    -Luc
    Yeah, you will not get the benefit of the ABT processor. Are you within the 30 day return? You will lose only the cost of shipping.
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
  • trubluluc
    Yes, it's only been 2 weeks. I didn't know they had a 30 day return policy, thanks for the heads up.
    I may buy this unit again, down the road some when I'm up for a new TV, but it's not this Christmas.
    -Luc
    vc69 wrote: »
  • vc69
    vc69 Posts: 2,500
    Send that puppy back and score a cheap player with decent upscaler/deinterlacing.
    Merry Christmas!
    -Kevin
    2 Channel:
    Oppo BDP-83 SE
    Squeezebox Touch
    VTL 2.5
    B&W 801's
    Transparent IC's
