Polk RM8 for home stereo?
Is anyone using RM 8 's for a home stereo?
I have space limits and would consider RM8 w/ a sub
Post edited by gwdgs on
Would you be referring to the rm8000T?Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
How about a Polk surround bar SDA instant home theater...see product menu above. A single bar placed beneath or above your TV and a matching sub...no wires.
I think he talking about the RM8 satellites that go in the RM85/95 5 packs maybe?Sony 40" LCD
Sony DVPCX995V
Sony PS3(games/media server)
Sony PS2
WD TV Live with 3TB
Sanyo VCR
Marantz SR6003
Polk 11T(xover/RDO)
RM20 5 pack
OWM 5
DUAL Micro Pro 1000
Combastard Cable
Harmony One
When rapture comes, can I have your car? -
I have 4 rm8's and would suggest against them for a home stereo. For HT they really are not to bad for how small they are, but for music you need something else. They only play down to 120hz, and you really don't want your sub to play that high. Why not get some of the RTi A3's instead off of polk direct. They would be much better sounding then the small rm8's. But if you really need something as small as the rm8's then they will probably surprise you with their sound for how small they are.Denon 1909, want to upgrade for pre outs
Fronts-polk RTi A5
center-polk CSi A4
Sides Polk FXi A6
rears- polk rm8's
sub-SVS pb-13 ultra
Blue ray-ps3
Panasonic plasma 50 inch
Buttkicker(don't use or need it anymore since getting the Ultra) -
I personally don't think this is a really good option for stereo music. I own the SB42 and out of curiosity I pushed some music through using my PSW110 and I wasn't too impress about the end result. Small drivers along with being encased into the same enclosure... I can't see good stereo sound coming out of that.How about a Polk surround bar SDA instant home theater...see product menu above. A single bar placed beneath or above your TV and a matching sub...no wires.
cnh
+1, I own/use RM10s, RM20s and SB42 (all use the same drivers) and they are decent for HT use in small room but music? Nah... I agree that RTi A3 would be a good option. In fact I've noticed decent pricing for the refurbs on the Polk direct site yesterday evening.I have 4 rm8's and would suggest against them for a home stereo. For HT they really are not to bad for how small they are, but for music you need something else. They only play down to 120hz, and you really don't want your sub to play that high. Why not get some of the RTi A3's instead off of polk direct. They would be much better sounding then the small rm8's. But if you really need something as small as the rm8's then they will probably surprise you with their sound for how small they are.
Cheers!
TKDARE TO SOAR:
