How to improve the sound quality of the squeezebox duet
Tomasito
Tomasito Posts: 142
edited December 2009 in Electronics
Hello Sound gurus,
I need your advice or recommendations.
I just purchase a squeezebox duet that is connected by coaxial to my Pioneer VSX94TH with polk speakers in all 7 channels.
I am not totally satisfied with the sound quality.
My digital audio media files are in WMA pro, MP3's, lossless, WMA - CD quality rip.
How can I improve the sound quality?
Should I use a DAC,
Is this the correct layout of the connection is like this squeezebox via coaxial or optical --> DAC --> VSX94TH
thanks in advance,
Post edited by Tomasito on
  • Tomasito
    Tomasito Posts: 142
    Not sure if this is the correct forum to post, if I am incorrect, my apologies, kindly tell me what forum to post my thread
  • thuffman03
    thuffman03 Posts: 1,325
    Have you tried to just use the L/R? That is what I am using and it sounds great. Though don't use the IC they put in with it. Connect with a better one.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Face
    Face Posts: 14,340
    An external DAC will definitely help.
  • thsmith
    thsmith Posts: 6,082
    Your AVR may not have that good of a DAC. Not sure the SB has one built in but you want to try as the poster above says and use the l/r out to your AVR.
    heiney9 Posts: 25,413
    WMA, MP3's suck so I'd say start there
  • Tomasito
    Tomasito Posts: 142
    How about WMA pro? is it a better format?
  • Tomasito
    Tomasito Posts: 142
    Face wrote: »
    What DAC do you recommend?
    thanks
  • thsmith
    Tomasito wrote: »
    Try Flac before diving into a DAC but if you do I like my PS AUdio III, a lot people like the Benchmark DAC 1.
    Tomasito wrote: »
    I use FLAC and nothing else.
  • Face
    Face Posts: 14,340
    I use WMP lossless since it's also compatable with my Zune HD.
    As for an external DAC, the Cambridge DacMagic and Musical Fidelity V-DAC are the two best bargains out there.
  • steveinaz
    steveinaz Posts: 19,545
    Moving to lossless for ALL of your files and an external DAC is the way to go...
  • Tomasito
    Tomasito Posts: 142
    what program can I use that can rip CD;s in WMP lossless or FLAC?
  • Face
    Face Posts: 14,340
    You can use Windows Media Player to rip to WMP lossless. Look in preferences.
  • Tomasito
    Tomasito Posts: 142
    thanks
    what program to use for FLAC
  • Montoya
    Montoya Posts: 506
    For your files that are mp3 or low quality use the sound Retriever function on the pioneer.
  • Tomasito
    Tomasito Posts: 142
    OK let me read the manual on how to do this
  • WesKParker
    WesKParker Posts: 43
    Here's a suggestion to help troubleshoot your issue. If you can hook up a dvd/cd player to your reciever with a digital (coax or toslink) and that sounds fine to you. Then you can be pretty sure the issue is in your files or to a less likely degree your sqeezebox's ability to decode the files. And i would say that if your CD/DVD player sounds fine to you, then a DAC probably isn't necessary.
  • m00npie
    m00npie Posts: 697
    Tomasito wrote: »
    thanks
    EAC - Exact Audio Copy
  • adam2434
    adam2434 Posts: 995
    As others have indicated, lossy compression via mp3, wma, etc. will limit your sound quality – and an outboard DAC won’t fix it.
    Building on what WesKParker suggested, rip a familiar, good-sounding CD to lossless (flac or wma lossless). Load up a DVD/CD player with the same CD and connect to your receiver with optical or coax. Connect the Squeezebox with optical or coax too – ideally you would use identical digital cables for the DVD/CD player and Squeezebox to eliminate cable type as a variable.
    Make sure the DVD player is set to bitstream as lpcm and make sure the Squeezebox is running at 100% volume with no volume adjustments or ReplayGain adjustments. This should ensure that you are getting the same bitstream to the receiver’s DAC, and that the bitstream is exactly what is on the CD.
    Switch back and forth between the DVD/CD player and Squeezebox while playing the same track. Determine if you can hear a difference. You will be comparing the DVD/CD player and Squeezebox from a purely transport standpoint. I have not been able to tell a difference in this type of comparison.
    The final thing to determine is whether you are satisfied with the sound. If not, try the analog outputs from the Squeezebox as an experiment. In this case you will be using the Squeezebox’ internal DAC. The internal DAC and analog output is nothing special, so it may sound worse than the receiver’s DAC.
    If you are not satisfied, definitely look into an external DAC.
    5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
    2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
    2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
    2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
    Kitchen: Sonos Play5.
  • Tomasito
    Tomasito Posts: 142
    This comparison will be a good experiment to do. I will do it tonight when I get back from work.
    thanks
  • Tomasito
    Tomasito Posts: 142
    You guys are correct. I changed the track I rip using the WMA pro format and then I rip again with WMA lossless. The sound quality changed. gggrrrrhhhhh the hard work is ripping all my CD collection to lossless formats.
    I performed the comparison that adam recommended. There is a very little difference between the squeezebox stream and the CD sound of the same track. Maybe I am bias (brains) knowing that this track was being played by a CD player. If I did a blind test probably it will hard to tell the difference.
    Should I still get a DAC?
  • beardog03
    beardog03 Posts: 5,550
    that seems to be the norm
    I have been reading/watching all of you go through the same thing, and ask all the questions....I will follow your progress and follow suit, as I have been playing with my new ipod and have it on good authority (inside tip from the kids) that I will be getting an itouch, or a music server type of thing this year for X-Mas....seems the whole family is relying on my wifes nephew to do his homework and pick one of those server things
    Sorry for the derail..!
    as I said earlier, everybody seems to eventually get an outboard DAC
    I think I will start shopping for one myself....couldn`t hurt, as I`m sure it would be better than the one you have in your AVR
    As Face stated before cambridge, music Fidelity, and Benchmark seem to be the ones to look into
    MF and benchmark are high on my list
    Parasound HCA-3500
    Cary Audio V12 amp (Jag Red)
    Jolida JD-100 CDP
    SVS PC-Ultra Sub
    MIT Shotgun S1 I/C`s
    AQ Black Thunder Sub Cables
    PS Audio Plus Power Cords
    :cool:
  • steveinaz
    Tomasito wrote: »
    Are you satisfied with the sound?
  • adam2434
    adam2434 Posts: 995
    Tomasito wrote: »
    What's your frame of reference for CD playback? What have you been using?
    Is the Squeezebox with lossless files and your receiver's DAC is good as what you had been using, and is that good enough for you?
    An outboard DAC can be a huge improvement over the Squeezebox' analog output assuming the rest of one's gear, as well as one's ears are discerning enough.
    What speakers do you have?
    Audioadvisor.com carries many highly regarded DACs at various price points from $300 and up. They have a 30 day satisfaction guarantee, so you could buy a DAC and return it if it doesn't meet your expectations. I think the Cambridge Audio DAC for $430 is a great piece for folks who don't want to spend a huge amount on their first external DAC. I already have 2 external DACs, but I really want to give the Cambridge a listen sometime.
  • Tomasito
    Tomasito Posts: 142
    My squeezebox is connected by co-ax to the VSX94TH. My frame of reference is the oppo CD player. Maybe I'll give a cambridge audio DAC from audio advisor a try.
