Vandersteen 2 Ci's
TroyD
TroyD Posts: 13,124
edited June 2011 in Speakers
Well, I've been spending a good bit of time with the Vandy's that I aquired at PF....so I thought that I'd post some thoughts....
If you aren't familiar with the Vandy's...google 'em. I'm not really going to go through the whole compliment on the mechanical side. Besides, I've not taken the socks off (which is a PITA) so what's underneath is really a moot point.
BLUF is that this is a hell of a speaker and a steal, relatively, on the used market.
That said, it's not perfect...but, keep in mind that the speaker that I'm using as a reference (Quad 988) is a LOT more expensive and a lot different in design. So, what will 3 to 4 franklins of Vandy buy you? A HELL of a lot.
You get bass extension, in SPADES. Time and phase coherence....I don't know that I've heard a more 'coherent' cone-based speaker. The ability to throw a soundstage that is not SDA-sized, but, I'd hate to live on the difference. Wide and deep without congestion at any volume. If you like Symphony...think Mahler...think Strauss...Bruckner. Big. Bombastic. You know where I'm going with this....I can't think of a speaker in it's price range (to include comparable SDA models) that can do symphony like the Vandys. This was a nice change of pace from the Quads that simply will not do the big scale of a full on symphony. In the WilliamTell Overature finale (TELARC SACD)...man, talk about blow your hair back. I'm reminded of the first time I heard it on "The Truth" (George's Carver rig). The bass wasn't as deep as the Carver's (whose is?) but, it was not skimpy and it was well defined.
Now, what doesn't it do? Well, not much, really. The one area that I can tell that I'm not listening to the Quads is the midrange. The Vandy's simply lack the air and delicateness of the Quads. Listening to Vince Guaraldi's piano on the Charlie Brown Christmas Album....it's all there, but there is just slight syrupy 'thickness' to the piano. Not unpleasant, mind you, but this is where ESL's in general and Quads in particular make thier money.
High end extension is excellent. FAR smoother than the Dahlquist DQ-10 (the closest think I can think of to the Vandy). I think as compared to the DQ-10, the same as the Quads, midrange air and detail is better. Everything else, not quite as good. The highs on the Vandy's are very smooth and non-fatiguing. Those familiar with the AR9's...similar. This is NOT a metal dome.
Anyhow...just some quick thoughts. For a couple hundred bucks, there isn't a speaker that I'd rather own. It compares favorably with SDA's (better than the non-SRS versions....not better than my 2.3tl's). Better than the Dahlquist DQ-10 or 20. The 20's are a very very similar speaker, harder to find and more expensive.
If you are needing a great all-around speaker, get a pair.
BDT
Post edited by TroyD on
  • hoosier21
    hoosier21 Posts: 4,420
    edited December 2009
    I know an idiot that had 2 pair of these and let them both go, know he is looking for a pair of 3A signatures.
    Great review
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dorokusai
    dorokusai Posts: 25,576
    Vandersteen is underrated and a used market bargain. I'd invest in another pair of those before another pair of SDA. It's one of the best time alignment arrays I've heard to date.
  • SolidSqual
    SolidSqual Posts: 5,218
    The 3A Signature is an amazing speaker for about $2K used.
  • hearingimpared
    hearingimpared Posts: 21,136
    Nice write up Bro. I would love to hear them.
    heiney9 Posts: 25,513
    How efficient are they? Could I run some Vandy 2Ci's w/ a 15 wpc tube amp in a small room?
  • TroyD
    TroyD Posts: 13,124
    I dunno...15wpc at LOW volumes, perhaps. For the record, I've been running them on a Classe and....*gasp*...Carver amp. I haven't hooked them up to the Heaths....when I do, I'll let you know.
    I'd forgotten how much I really like Carver amps. They don't have the bass weight/definition of the Classe...but it's a good listen all the same.
    BDT
  • Conradicles
    Conradicles Posts: 6,379
    edited June 2011
    Bump...any other thoughts before I jump on a pair?
    Tony M Posts: 11,732
    edited June 2011
    I had a chance to get a pair for 250.00 but we never got together. I told him I just really wanted to hear and look at them first and even maybe trade. I don't think he like the thought of a LOOKER.:frown:
    I'll be more diligent next time some come up for sale locally. If they do.:redface:
    txcoastal1 Posts: 13,519
    edited June 2011
    http://www.google.com/search?sourceid=navclient&aq=1&oq=Vandersteen+2+Ci&ie=UTF-8&rlz=1T4ADFA_enUS422US423&q=vandersteen+2ci+speakers
    Quite a few listings of good reports which I am sure you have found....sounds like to me if you have that tickle $250 not a bad deal
    Good luck with your decision
