Polk RTi4 or Polk TSI200
What speakers would you buy.
Reason for question is Dealer only has RTi in stock.
Sorry for the dumb question
Post edited by gwdgs on
Not a dumb question, but are there other speakers in your system?
Welcome to the Club!
Go for the Tsi200 with the dual drivers.Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
No I don't have any other speakers.
Just rebuilding my system from scratch.
So far I have a Yam rec and Nak cd.
Space is a major problem, have also been
thinking about polk RM8 with a sub.
old sys was musical fidelity a3 (ia), canton (spkrs)
Nak (cd)
Thanks for your comments! -
If you're building from scratch then you need to consider that you're buying into a series..if you buy RTI you should stay in that series and if you go TSI the same...you should listen to both and see what you think...RTIs are usually very good at HT....TSIs have gotten better there too....but can do double duty better at least for me...I know a lot of people here listen to music on Rtis as well.
Get thee to a Best Buy and listen to the TSI series..if they don't have the 200s they will definitely have the 300s which have more bass but sound very similar otherwise.
I have had the RTi4's for a few years now, and I have no regrets. I use them exclusively for listening to music. Mostly progressive metal and jazz.
I cannot comment on the Tsi200's, so my post is probably not very useful as a comparison, but I think you will be happy with the RTi4's. -
Welcome to the Club Greg!
See...I told you they're out there RTIs might be fine for you..but go listen!
