GNX104 question
Zades
I've just bought and received two Polk GNX 104s from Crutchfield with the suggested 0.65 cu.ft sealed boxes. In addition, I have a Pioneer Premier 550MP (w/ WMA and MP3 playback); two US Acoustic 2100 (300x1 @ 4 ohms); and one 1-farad capacitor to keep everything clean. Oh yeah, I also have Infinity Reference 6.5" coaxs in the doors and I-R 6x9s in the rear deck...
---Honda Accord '98 LX--
I have also installed 6x9 inch baffles in the rear so that the airpressure from my subs don't affect the 6x9's cone excursion
I thought that the system would be a beauty to behold...Power, Accuracy...elegance...:-)
Well, that's simply not the case...
I am most disappointed in my subs...for the Infinities are doing wonders with the mids and highs as I wanted them to do...but the subs are truly unsatisfactory
I have positioned my sub box in every possible way, and I remain displeased...
As with anything, at low volumes the sub sounds pretty good, but once I start towards higher volumes, there is much bass distortion and clipping...and I have yet to hear them "pound" as reviews that I have read professed.
I hypothesize that my box is too small and actually have Acousti-stuf to increase the apparent size (2 lbs of the stuff). However, as I have done since I was twelve (and am now 20) I drill my holes by hand, and I would hate to take the subs out put the material in and still be displeased.
Anyone have any ideas?
"Nothing is Impossible"
Post edited by Zades on
well... you could just need a major "tune up" -- ie box placement / stuffing / adjusting xover or what not.
or it could just not be the sub for you.
the GNX is a "smooth" sub more than it is a "banger".
It'll bump, but its not going to make your ears bleed... take a look at what the amps do... 300 x 1 at 12.9 volts -- call it 325 or so with teh car running. the gnx is rated like 175 -- dump maybe 200 on it... over that and you're really using it in a manner that's beyond its means.
i only say this b/c you're saying it sounds fine at lower volumes then u juice it and it goes to hell. u could simply be overpowering them.
while they may sound best in a ported box as kim says, i dont know if that's going to give u the sound quality that you want. freq-resp changes... and if you're a real nut about your precision, you're going to want that sealed -- also -- then you'd have to go through the pain of building a new box.
try it with the gains down a little... maybe just turn the gains back about 20% from where they're at now... and then add a little bass at the deck, shape it a little better, play with the xover and see what happens for a few days. you may be pleasantly surprised.
if that's no good... if crutch will take them back -- send back the amps and the subs and get a pair of momo's ... or hell for the same price u paid for 2 GNX's u canprolly get one momo 12 --- that alone will probably out boom the two gnx's... might not sound as clean / punchy, but it'll outboom it w/ around 5 - 600 watts.The Artist formerly known as PoweredByDodge -
Indeed, Dodge, I do prefer the accuracy, although the comment by Kim is rather inspiring...
Funny thing: on the day that I posted this, I caroused around the boards and noticed some truly informative information regarding my amplifier settings. I DID set the voltage too high.
Once I turned it back down to around 4V (my Premier HU gives out 2.2V Max) I was pleased to hear the beauty that is a sealed enclosure.
And yes, the GNX104s are a rather unbiased bunch. My music sounded flat and extremely precise. The soundfield is much like that I receive from my home stereo.
Once I did read the posts regarding amplifier settings, I realized the fact that My US Acoustics 2100s are but POWER Amplifers...they aren't pre-amps. The understanding that the voltage setting only regards that from the Pre-amplifying device's capabilities has truly assisted me in this novice project.
Next year, I am going to up my system and might consider getting the Momos--or another powerful sub that operates in a sealed enclosure--and purchasing component sets...
I'll probably come here again for ideas on that...
Thanks folks..."Nothing is Impossible"
