Dumb question of the day
I'm a newbie at this so don't flame me too badly. lol I've had a pair of monitor 10b's since new. I always thought they were 4 ohm speakers, but I think I read somewhere they were 8 ohm......I'm confused:o
can someone straighten me out on this?
Post edited by tonyr1 on
I can't tell you the answer but, I CAN add to your confusion by telling you that some Polks are 6ohms also !! :eek: With the flaky record keeping and mid-run changes that were made, I'd say if you want to be absolutely sure about the impedance, you should have someone test them with a multimeter.;)
Driver Complement
Subwoofer 1 - 10" Diameter (25.40cm)
sub bass radiator
Midrange 2 - 6-1/2" Diameter (16.51cm)
drivers
Tweeter 1 - 1" Diameter (2.54cm)
Polk SL2500
Electrical
Overall Frequency Response 25Hz - 25kHz
Lower -3dB Limit 37Hz
Upper -3dB Limit 25kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 20-250 w/channel
Efficiency 89 dB
Dimensions
Cabinet Size 28" H x 15" W x 12" D
(71.12cm H x 38.10cm W x 30.48cm D)
Shipping/Other
Total Shipping Weight 46.00 lbs. (20.87kgs)TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX -
Driver Complement
sub bass radiator
drivers
Polk SL2500
Electrical
Efficiency 89 dB
Dimensions
Shipping/Other
Those are the specs for the Monitor 10 Series II. He has a pair of Monitor 10B's...slightly different speaker.
Generally speaking, the Monitors are usually about 6 ohm nominal.The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
What are you powering them with? The impedance shouldn't matter too much as long as your amp is stable and not clipping. Welcome and enjoy.
Run an amp that can handle 4 ohms stable and then don't worry about a thing. If you have a Monitor A or B I believe they are 6 ohms. I am not sure about Monitor C's. Do you know which Monitors you have. If there is a fuse on the back they are older models.Polk HT system 1: LSIC, LSI25 mains, LSI F/X rears, Lsi F/X rear centers,
Yamaha RX-V2500 System, Carver A753 3 channel amp.
Polk HT system 2: , SRT system with f/x 1,000's rear speakers on 7.1 system currently using Onkyo TX-RZ820 receiver, powered by Sunfire Grand Theater amp
Polk Speaker collection: SDA SRS 1.2tl x 2, SRT system, SDA SRS 2 P/B, SDA 2A, SDA 1C Studio, SDA CRS+, Monitor 7B & 4, SRS 3.1tl, RTA 15tl, LS90, LSI 9 -
when I bought them I bought a Harman Kardon pm665 , had problems with them cutting out when too loud. then I had a Yamaha HT amp, can't remember the model, same problem. then I bought a JVC RX DP15 7.1 . same problem. now I have bought an Adcom 555 on ebay....maybe that will finally be the one that will power these things without problems. might look into using the HK 665 for a pre-amp until I can get an Adcom 715 or 750. -
I believe they are b's. I had a pair with fuses for a couple of years until they were stolen. these ones were the replacements. no fuses. I have an Adcom 555 on the way, should do the job. -
I believe the impedance rating on a speaker is based on reactance thus rendering a multimeter useless. Someone please correct me if I'm wrong. -
That Adcom 555 will do a wonderful job of powering them. I've got my Adcom 545 running my Monitor 7A's(6 ohm nominal) right now, and it sounds fantastic. It can drive them to levels louder than I ever care to listen to.
That 555 is VERY stable at low impedances.The nirvana inducer-
