Center Channel Speaker
jeffk726
jeffk726 Posts: 2
edited December 2009 in Speakers
Finally hooking up equipment two years after building new home. Everything is prewired - only one problem. The TV which is above the fireplace mantel did not leave enough room to put a standard center channel speaker. I only have approximately 4" above the tv. I was always thinking that I could get a low profile speaker and mount it directly to the ceiling slightly in front of the tv. Polk does not offer a $250-400 low profile center channel speaker. Has anyone tried using a in ceiling / in wall speaker mounted in the ceiling? I was looking at the Polk Audio TC60i. Any thoughts?
Post edited by jeffk726 on
    Tony M Posts: 11,726
    Welcome ,
    What about mounting options on the sides of the TV?
  • superjunior
    superjunior Posts: 1,632
    welcome aboard. what are you using for front speakers and how much room is between the bottom of tv and mantle?
    panasonic th-50pz85u
    pioneer elite vsx-92txh
    pioneer elite bdp-05fd
    emotiva xpa-3
    monster power hdp 2550
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    surrounds - fxi a6's
    sub - polk dsw pro 600
    harmony one
  • jeffk726
    jeffk726 Posts: 2
    Tsi 200 fronts - equal distance on top and bottom to the antle and ceiling - 4". The whole wall tha the tv is mounted to is all stone. Thanks for your help.
  • superjunior
    the cs2 would be the best match for your 200s, but where to put it. I honestly haven't heard anything (good or bad) about the tc60i, but if the tv is that close to the ceiling it may be your best option. pics might help
    emotiva xpa-3
    sa 8300 hd dvr
    sda 2b's
    fronts - rti a9's
    center - csi a6
    harmony one
    ...Deleted...:rolleyes:
