Cabling for PSW111 subwoofer
edh01542
I just purchased a PSW111 subwoofer and need to purchase cabling for it. The house was pre-wired for surround-sound and it has a wall outlet to plug the cable into. Any advice on the quality/type of cable - RCA?
I bought an Onkyo TXNR807 AVR which I'll need to hook up to - its got a ton of connection options - very confusing!
I purchased Polk CS20 center speaker and TSi 400s to complete the package.
Front Floor Speakers: Polk TSi 400s
Center Speaker: Polk CS20
Subwoofer: Polk PSW111
Surround Speakers: Polk OWN3s
AVR: Onkyo TXNR807
AVR: Onkyo TXNR807
Post edited by edh01542 on
I would say that it depends on the quality of you other cables as to what exact cable you need. It is a typical RCA cable. You can pick up a sub/rca cable at bestbuy or Radio shack or something. Or online for a little cheaper. There should be a subwoofer preout on the AVR to connect it to.
hope this helps.Front - RTiA5's
Rear - RTiA3's
Center - CSiA4
Sub - PSW110
